Undefined references to mkl objects
Sresht__Vishnu
I'm attempting to compile OpenCV with Intel MKL 2017.0 on Ubuntu 16.04.1 with , but I keep running up against the following errors at compile time:
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_lp64_ccsr0ttluc__svout_seq'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_zlantp'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_sdia1ttluf__mvout_par'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_lp64_ccsr1ntuuf__mvout_par'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_blas_xdgemv'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_ccsr1ntuuf__smout_par'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_sparse_d_csr_ng_n_spmmd_ker_i4'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_ccoo0nhluc__mvout_par'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_sequential.so: undefined reference to `mkl_spblas_lp64_dcsr1ttluf__svout_seq'
/opt/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.so: undefined reference to `mkl_lapack_dgelsd'
I have installed Intel MKL and I have the following in my zsh startup script:
source /opt/intel/mkl/bin/mklvars.sh intel64
I also have the following in /etc/ld.so.conf.d/intel_mkl.conf :
/opt/intel/lib/intel64
/opt/intel/mkl/lib/intel64
CMake manages to find MKL and reports:
-- Found MKL 2017.0.1 at: /opt/intel/mkl
-- LAPACK(MKL): LAPACK_LIBRARIES: /opt/intel/mkl/lib/intel64/libmkl_core.so;/opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so;/opt/intel/mkl/lib/intel64/libmkl_sequential.so;/opt/intel/mkl/lib/intel64/libmkl_core.so;/opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so;/opt/intel/mkl/lib/intel64/libmkl_sequential.so;/opt/intel/mkl/lib/intel64/libmkl_core.so;/opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so;/opt/intel/mkl/lib/intel64/libmkl_sequential.so;-lpthread;-lm;-ldl
-- LAPACK(MKL): Support is enabled.
CMake also lists:
--     Use Intel VA-API/OpenCL:     NO
--     Use Lapack:                  YES (/opt/intel/mkl/lib/intel64/libmkl_core.so /opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so /opt/intel/mkl/lib/intel64/libmkl_sequential.so /opt/intel/mkl/lib/intel64/libmkl_core.so /opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so /opt/intel/mkl/lib/intel64/libmkl_sequential.so /opt/intel/mkl/lib/intel64/libmkl_core.so /opt/intel/mkl/lib/intel64/libmkl_intel_lp64.so /opt/intel/mkl/lib/intel64/libmkl_sequential.so -lpthread -lm -ldl)
--     Use Eigen:                   NO
--     Use Cuda:                    YES (ver 8.0)
--     Use OpenCL:                  YES
What am I missing? Are there any additional compile flags I should be specifying?
Jing_Xu
Could you store the following 3 when compiling OpenCV against MKL, and then share with us?
1. history of commands, step-by-step.
2. environment variables (before execution of cmake). They could be exported to file with the following command on Linux: env > filename.
3. cmake history. They could be redirected to file with the following command on Linux: cmake ......... 2>&1 | tee filename.
kobe_y_
Hi
I have the same problem, I just workaround by add flag "-D WITH_LAPACK=OFF".
Sresht__Vishnu
Hi Jing,
Here's what I did:
  1. Installed MKL using the instructions here: https://software.intel.com/en-us/articles/intel-mkl-113-install-guide
  2. Added the following to (a new) file /etc/ld.so.conf.d/intel_mkl.conf:
  3. Added the following to my .zshrc file:
  4. Clone the OpenCL repository at https://github.com/opencv/opencv.git
  5. Clone the OpenCL extras repository at https://github.com/opencv/opencv_contrib.git
  6. Run CMAKE from within a freshly created 'release' directory within the cloned opencv repository:
    cd opencv
    mkdir release
    cd release
    cmake -D CMAKE_BUILD_TYPE=RELEASE \
          -D CMAKE_INSTALL_PREFIX=/opt/opencv \
          -D WITH_CUDA=ON \
          -D ENABLE_FAST_MATH=1 \
          -D CUDA_FAST_MATH=1 \
          -D WITH_CUBLAS=1 ..  \
          -D INSTALL_PYTHON_EXAMPLES=ON \
          -D WITH_OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules \
          -D WITH_TBB=ON \
          -D BUILD_NEW_PYTHON_SUPPORT=ON \
          -D WITH_V4L=ON \
          -D INSTALL_C_EXAMPLES=ON \
          -D BUILD_EXAMPLES=ON \
          -D WITH_QT=ON \
          -D WITH_OPENGL=ON \
          .. 2>&1 | tee build_output.log
  7. make -j8 > >(tee make_output.log) 2> >(tee make_errors.log >&2)
  8. ERROR
I have attached files listing my environment variables, cmake output, build output and build errors to this post. I hope they help you help me figure out what's going on!
Sresht__Vishnu
kobe yu wrote:
Hi
Hi Kobe,
That's an excellent idea and it totally works! However, I would still like to know why I'm unable to link Intel's lapack to OpenCV and I'm hoping you, or someone else, can help me figure this out.
Sresht__Vishnu
I found a fix that allows you to compile OpenCV using MKL.
All of those undefined references were references to objects in libmkl_core.so. Even though this library is specified in the link line, gcc on Ubuntu 16.04 doesn't look inside it when searching for these items.
The fix was to specify -Wl,--no-as-needed in the link line before the Intel MKL libraries. This can be accomplished in a CMAKE-based project by setting the variable CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=-Wl,--no-as-needed in CMakeCache.txt
Jing_Xu
Great to hear that.
Thank you for sharing the solution.
Ying_H_Intel
Hi Vishnu,
thanks much for the sharing.  We can't reproduce the problem under Linux.  But the issue do related to the system and mkl library.
all unreferenced symbols like mkl_lapack_zlantp  are defined in libmkl_core.so
[yhu5_new@hsw-ep01 cmake]$ nm  /opt/intel/mkl/lib/intel64/libmkl_core.so |grep mkl_lapack_zlantp
0000000000a14d20 T mkl_lapack_zlantp
"libmkl_intel_lp64 libmkl_sequential libmkl_core " are supposed to be used together and here in the link line, the combination were repeated several times, but miss mkl_core at last one.
So It seems there is some problem in FINDLAPACK.cmake processing( OpenCVFindMKL.cmake).  the fix is  CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=-Wl,--no-as-needed
or like the article https://software.intel.com/en-us/articles/symbol-lookup-error-when-linking-intel-mkl-with-gcc-on-ubuntu
If possible, could you please try Set environment variable >export  LD_PRELOAD=/path/to/libmkl_core.so and see if it can work around?
Ying
Sresht__Vishnu
Hi Ying,
Thank you for that alternate solution. Yes, setting LD_PRELOAD=/path/to/libmkl_core.so also works. So apparently, there is some issue when it comes to the combination of gcc, mkl, and ubuntu. Fortunately the two workarounds above seem to work.
