7303 Discussions
Uninitialised memory access in 'cblas_cgemm'
Chandrakant_19
Hi Intel Support Team,
I am working on a project using mkl library. I am using the 'cblas_cgemm' mkl routine for complex matrix multiplication.
I have initilaized the input parameters before before calling the api.
Code Snippet:
int m = 2, n = 2, k = 2;
int lda = 2, ldb = 2, ldc = 2;
MKL_Complex8 alpha = {1.0, 0.0};
MKL_Complex8 beta = {0.0, 0.0};
MKL_Complex8 A[4] = {};
MKL_Complex8 B[4] = {};
MKL_Complex8 C[4] = {};
A, B is overwritten with actual data.
cblas_cgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans, m, n, k, &alpha, A,
lda, B, ldb, &beta, C, ldc);
On Intel Inspector in windows envirounment, we are observing following error
"Uninitialized memory access"
Thanking you.
Gennady_F_Intel
Checking the problem you reported with the current version of oneMKL ( 2024u1), I see no problem.
Here is the log file
$ valgrind --tool=memcheck --track-origins=yes --leak-check=full ./a.out cblas_cgemmx.d > 2.log 2>&1
==1172046== Memcheck, a memory error detector
==1172046== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==1172046== Using Valgrind-3.18.1 and LibVEX; rerun with -h for copyright info
==1172046== Command: ./a.out cblas_cgemmx.d
==1172046==
   C B L A S _ C G E M M EXAMPLE PROGRAM
   INPUT DATA
    M=2 N=4 K=3
    ALPHA =( 0.5, 0.0 ) BETA =( 1.2, 0.0 )
    TransA = CblasTrans TransB = CblasTrans
    LAYOUT = CblasRowMajor
    ARRAY A  LDA=2
     ( 1.00, 0.10)  ( 2.00, 0.00)
     ( -3.20, 0.40)  ( -2.70, 1.10)
     ( 0.00, 0.70)  ( 4.00, 0.00)
    ARRAY B  LDB=3
     ( 1.00, -1.00)  ( 2.00, 2.30)  ( 3.00, 0.00)
     ( 1.00, 1.00)  ( 2.00, 0.00)  ( 3.00, 0.80)
     ( 1.00, -1.00)  ( 2.00, 0.60)  ( 3.00, 0.00)
     ( 1.00, -1.00)  ( 2.00, 0.10)  ( 3.00, 0.10)
    ARRAY C  LDC=4
     ( 0.00, 0.00)  ( 0.00, 0.10)  ( 1.00, 0.10)  ( 1.00, 0.00)
   OUTPUT DATA
    ARRAY C  LDC=4
     ( -3.11, -2.68)  ( -3.03, 2.12)  ( -1.57, 0.16)  ( -1.51, 0.84)
     ( 3.04, -3.01)  ( 4.30, 3.82)  ( 5.17, -0.59)  ( 5.45, 0.17)  ==1172046==
==1172046== HEAP SUMMARY:
==1172046==   in use at exit: 11,803 bytes in 31 blocks
==1172046==  total heap usage: 99 allocs, 68 frees, 4,410,855 bytes allocated
==1172046==
==1172046== LEAK SUMMARY:
==1172046==  definitely lost: 0 bytes in 0 blocks
==1172046==  indirectly lost: 0 bytes in 0 blocks
==1172046==   possibly lost: 0 bytes in 0 blocks
==1172046==  still reachable: 11,803 bytes in 31 blocks
==1172046==     suppressed: 0 bytes in 0 blocks
==1172046== Reachable blocks (those to which a pointer was found) are not shown.
==1172046== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==1172046==
==1172046== For lists of detected and suppressed errors, rerun with: -s
==1172046== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
Gennady_F_Intel
It might be the same issue as you reported against Lapack cheev routine.  Which version of Inspector do you use?
and again - is that oneMKL 2024u1?
Could you show how do you link against oneMKL?
Chandrakant_19
Please find below details about compilers and libraries.
IntelSWTools (Linux) - compilers_and_libraries_2016.2.181
IntelSWTools (Windows) - compilers_and_libraries_2017.1.143
Intel Inspector 2023.0
Thanking You.
Gennady_F_Intel
==1172046==
   INPUT DATA
    M=2 N=4 K=3
    ARRAY A  LDA=2
    ARRAY B  LDB=3
    ARRAY C  LDC=4
   OUTPUT DATA
    ARRAY C  LDC=4
==1172046==
==1172046==
Gennady_F_Intel
this thread is closing.
