7292 Discussions
Update from 2024.1.0.692 to 2025.2.0.627 is causing problems with FFT
MS_SHS
We are using P/Invoke with C#
We are trying to update to 2025.2.0.627 but are facing problem in the FFT.
No code has been changed in between, the only change is to update from 2024 to 2025 using the nuget packages intelmkl.redist.win-x64.
I checked if some default configuration has changed by inspecting all values using DftiGetValue but our tests show no difference.
When committing the descriptor we get an DFTI_INCONSISTENT_CONFIGURATION error.
It seems that only the batch cases fail.
Has there been some change?
