Usage of mkl_free_buffers
erling_andersen
Suppose I have an application that links MKL static and nonthreaded. Also assume I call MKL functions from several threads.
That should be fine. However, now I speculate how
mkl_free_buffers
works in this setting.
Can I call at any time and it will not crash? What if I call the function and buffer is in use?
Should I use another function to free all the buffers.
Erling
barragan_villanueva_
Valued Contributor I
mkl_free_buffers function just releases memory for that buffers which are not in use and marked internally as free.
So, such buffers are conditionally taken to be used fast if such buffer will be required.
