Use array of floats as argument
Carlos_Alexandre_T_
Is it possible to use an array of floats as parameters when using dgemm?
Ying_H_Intel
Hello Carlos,
MKL function allows float array, either double or single floats as input.  for example,
double A[m*k];
B = (double*) malloc(sizeof(double)*k*n);
C = (double*) malloc(sizeof(double)*m*n);
dgemm(&transa, &transb, &m, &n, &k, &alpha, A, &m, B, &k, &beta, C, &m);
Moreover, the first letter in *gemm indicate the data type.  and you can see many sample codes under <MKL install dir>/examples/
for example, C:\Program Files (x86)\Intel\Composer XE 2013\mkl\examples\cblas\source
s real, single precision
c complex, single precision
d real, double precision
z complex, double precision
Ying
P.S it seems the post was showned many times, we will delete the rest of them.
Ying_H_Intel
Hello Carlos,
double A[m*k];
Ying
Carlos_Alexandre_T_
Thanks a lot!
Did you see this under MKL's Documentation?
Ying_H_Intel
Hi Carlos,
Right, MKL Documetation(MKL manual and MKL userguide) includes the informations.
The doc can be found in MKL install directory or from on-line documentation: http://software.intel.com/en-us/intel-software-technical-documentation
Ying
