Use of iparam(30) for PARDISO
Alemdar__Bulent
Hi
I just started using v10.2 update 2 and found that for mytpe =2, PARDISO reports the number of equation when it detects a zero:
"iparm(30) - the number of equation where PARDISO detects zero or negative pivot for MTYPE=2 (real positive
definite matrix) and MTYPE=4 (complex and Hermitian positive definite matrices). If the solver detects a zero or negative pivot for these matrix types, the factorization is stopped, PARDISO returns immediately with an error (error = -4) and iparm(30) contains the number of the equation where the first zero or negative pivot is detected."
As far as I remember, PARDISO does an internal equation ordering for the given matrix. I just want to know the reported Equation # is the equation number associated with PARDISO's internal ordering or the equation number referring to my original matrix. The former really deos not help since we have no idea how the PARDISO internally orders equations. Thus, what I really need is the one that refers to the order given with the original matrix.
Bulent
Alemdar__Bulent
Quoting - bulent
Hi
Bulent
ALso, I noticed that I am getting different equation number when I change my preference for fill-in reducing order:
iparam[2] = 0 : minimum degree algorithm
iparam[2] = 2 : nested dissection from METIS
B.
Konstantin_A_Intel
Hello Bulent,
The number of first zero/negative pivot relates toinitial matrix A.
But it's Ok ifthe numbers are different for METIS and MMD reorderings. It just means that the order of factorizationwas different as well and we faced the very first zero/negative pivot at diferent places of the matrix (if your matrix contains more than one). This numbermay also vary even if we use several threads for computation as threadsmay compute matrix columns in parallel: it's an indeterministic process.
Hope that I answered your question.
regards,
Konstantin
Konstantin_A_Intel
Bulent,
I have one more comment: you mentioned that do not know anything about reordering using inside PARDISO. That's not true; you may simply obtain a permutation vector used for reordering: just set iparm(5)=1 and it will be copied to your 'perm' array after the "Reordering and symb.factorization" phase of PARDISO (1st calling of pardiso function).
More details could be found in mklman.pdf
Konstantin
Konstantin_A_Intel
Bulent,
Konstantin
I'm sorry, iparm(5)=2 is correct.
Alemdar__Bulent
Hello Bulent,
regards,
Konstantin
Konstantin
Thanks for clarying the fact that it reports the 1st nonzero eqution refering to the original matrix. I might have more than one negative diagonals so that different ordering returns different 1st nonzero pivoting eqution. I will run furter examples.
bulent
