Using LAPACK to invert sparse matrices
thomasdd
I've some small square matrices (so around 100x100) that are sparse. I want to use the LAPACK functions to compute the inverse. To do this, I've tried to use the function dgetrf (in C++). But always the info return value is > 0. I've checked the matrix, but it has no zero values on the diagonals. Because the matrix is square, I can use n=m=lda for the input parameters. Is it right? Is there any trouble known when using sparse matrices with LAPACK? I've also check the matrices in Matlab, they are non-singular.
Thanks for any hints,
Thomas
Gennady_F_Intel
Quoting - thomasdd
Quoting - Melvin
Can you post some example code so that I can see what you are doing?
A very simple example:
int n = 4, m = 4, lda = 4;
int ipiv = 0, info = 0;
double matrix[16] = {1, 0, 0, 0,
0, 1, 0, 0,
0, 0, 1, 0,
0, 0, 0, 1};
dgetrf(&m, &n, matrix, &lda, &ipiv, &info);
std::cout << "INFO = " << info << std::endl;
In this case, info is 4! Is there anything wrong in the call of dgetrf?
Thomas
Thomas,
ipiv is the array, but not integer
the dimention at least max(1,min(m,n)), therefore for your case ipiv[4].
Please refer to the mkl's reference manual.
--Gennady
Melvin_Robinson
Quoting - thomasdd
Thomas
thomasdd
Quoting - Melvin
0, 1, 0, 0,
0, 0, 1, 0,
0, 0, 0, 1};
Thomas
Gennady_F_Intel
Quoting - thomasdd
Quoting - Melvin
0, 1, 0, 0,
0, 0, 1, 0,
0, 0, 0, 1};
Thomas
Thomas,
--Gennady
thomasdd
Thomas,
--Gennady
Thank you very much! Now it works fine. I was too fast in reading the reference :)
Thomas
