Using Lapack with ifort on linux
notmuchnoise
I was wondering if someone could help me please?
Im trying to access some of the routines in the lapack
In my f90 code i have
program a
use mkl95_lapack
implicit none
etc
call steve(variables here)
Normally I would compile a program with "ifort program.f90"
i use this to set ifort up prior to compiling "source /opt/intel/Compiler/11.1/064/bin/ifortvars.sh intel64"
The ifort files are located along the file tree "/opt/intel/Compiler/11.1/064"
with the mkl directory at "/opt/intel/Compiler/11.1/064/mkl"
I'm unsure as to what commands I would use now that I require the use of lapack?
at the moment i get the following error:
a.f90(2): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL95_LAPACK]
use mkl95_lapack
compilation aborted for a.f90 (code 1)
Thanks for any help
(sorry about the very beginner question)
ArturGuzik
Valued Contributor I
Compiler makes it clear, can't find module you specified. check your LD path first, to make sure compiler knows where to find it (/include folder). On the other hand, you say that you set the environmen already. What about location for *.mod files?
A.
Ying_H_Intel
The mkl95_lapack.mod is in /opt/intel/Compiler/11.x/0xx/mkl/include/[32|em64t]
Assume 32bit,the command may like
ifort -I//opt/intel/Compiler/11.x/0xx/mkl/include/32 main.f
-L/opt/intel/Compiler/11.1/059/mkl/lib/32 -lmkl_intel_c -lmkl_intel_thread -lmkl_core -liomp5
See more details from
http://software.intel.com/en-us/articles/blas-and-lapack-fortran95-mod-files/
http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
Ying
