Using MKL with MKL_NUM_THREADS=1
DmitrySkachkov
I am trying to use MKL to calculate on one core only, but within the cycle working in OpenMP parallel regime.
Program A
!OMP PARALLEL DO
 do k=1,N2
  call getrf(A,ipiv)         ! MKL subroutine to work on one core
  call getrs(A,ipiv,B)       ! MKL subroutine to work on one core
 enddo
!OMP END PARALLEL DO
 In job submission script I set
export OMP_NUM_THREADS=2
export MKL_NUM_THREADS=1
However this gives an error in MKL subroutines!
When I submit the job on one core only (OMP_NUM_THREADS=1) the MKL subroutines work correctly.
How to ask MKL library to calculate on one core correctly when the program runs in OpenMP parallel regime?
Ruqiu_C_Intel
For using oneMKL + OpenMP threading, we recommend you use intel OpenMP -liomp5 link option. For example,
 ${MKLROOT}/lib/libmkl_blas95_ilp64.a ${MKLROOT}/lib/libmkl_lapack95_ilp64.a -Wl,--start-group ${MKLROOT}/lib/libmkl_intel_ilp64.a ${MKLROOT}/lib/libmkl_intel_thread.a ${MKLROOT}/lib/libmkl_core.a -Wl,--end-group -liomp5 -lpthread -lm -ldl
More advisor, please check onemkl-link-line-advisor
Ruqiu_C_Intel
DmitrySkachkov
Thank you!
With this options MKL works as necessary, in OpenMP regime MKL subroutine runs on one core without errors.
