7303 Discussions
Using and linking of the blas library using 95 interfaces
rotero
Greetings,
Following the advice found on this group, specifically this post:
http://softwarecommunity.intel.com/isn/Community/en-US/forums/permalink/30232854/30232857/ShowThread.aspx#30232857
I have compiled the interfaces for blas95 and lapack95, placing the three generated modules into the include directory.
Then I sought to create a small test function:
program test
use mkl95_blas, only: dot
real(kind=8), dimension(4) :: a=(/1.,2.,3.,4./), b=(/4.,3.,2.,1./)
real(kind=8) :: c
c = dot(a,b)
write(*,*) 'c=', c
end program test
I compile the program with the following command:
ifort -o run test.f90 -L/opt/intel/mkl/10.0.1.014/lib/64 -I/opt/intel/mkl/10.0.1.014/include -lmkl_blas95 -lmkl
But get this output:
ld: /opt/intel/mkl/10.0.1.014/lib/64/libmkl_intel_lp64.so: warning: sh_link not set for section `.IA_64.unwind'
ld: skipping incompatible /opt/intel/mkl/10.0.1.014/lib/64/libmkl_intel_lp64.so when searching for libmkl_intel_lp64.so
ld: cannot find libmkl_intel_lp64.so
my machine is:
Linux richard-debian 2.6.22-3-amd64 #1 SMP Sun Nov 4 18:18:09 UTC 2007 x86_64 GNU/Linux
Is there something that I am just missing here? I have been trying to look through the reference documents.
Any guidance would be appreciated.
thank you,
Richard
TimP
MKL /64 directory is for IA-64. The x86-64 libraries are in /em64t.
rotero
Thank you Tim, that was most definitely the problem.
For the sake of documenting:
1) recompiled the fortran 95 interfaces for em64t
make PLAT=lnx32e INTERFACE=mkl_blas.f90 lib
make PLAT=lnx32e INTERFACE=mkl_lapack.f90 lib
2) Then the compile
ifort -o run -L/opt/intel/mkl/10.0.1.014/lib/em64t test.f90 -lmkl_blas95 -lmkl_em64t
Works; thank you for your help.
Richard
