Using fgmres_full_funct sample
Ivan_R_1
Dear Intel MKL User,
I try to see into a matter of MKL for solving systems of second order with symmetrical and unsymmetrical matrixes. Therefore I tried to analyze the examples and got stuck with part of code fgmres_full_funct with preconditioner calling. I didn't understand the code below (especially for tmp(ipar(23)+0,1,..4) assignment.
I wonder if anyone could explain it:
! If RCI_REQUEST=3, then apply the preconditioner on the vector
! TMP(IPAR(22)) and put the result in vector TMP(IPAR(23))
      IF (RCI_REQUEST.EQ.3) THEN
          IF (IPAR(4).EQ.3) THEN
              TMP(IPAR(23)+0)=-2.0D0
              TMP(IPAR(23)+1)= 0.08519601586107672D0
              TMP(IPAR(23)+2)=-1.1590871369607090D0
              TMP(IPAR(23)+3)=-0.65791939687456980D0
              TMP(IPAR(23)+4)= 0.75660051476696133D0
          ELSE
              IF(IPAR(4).EQ.4) THEN
                  TMP(IPAR(23)+0)= 0.0D0
                  TMP(IPAR(23)+1)= 0.0D0
                  TMP(IPAR(23)+2)= 0.0D0
                  TMP(IPAR(23)+3)= 1.0D0
                  TMP(IPAR(23)+4)=-1.0D0
              ELSE
              DO I=0,N-1
                  TMP(IPAR(23)+I)=I*TMP(IPAR(22)+I)
              ENDDO
              ENDIF
          ENDIF
          GOTO 1
      ENDIF
Ivan
Gennady_F_Intel
RCI_request= 3
apply the preconditioner to tmp[ipar[21] - 1:ipar[21] + n - 2], put the result intmp[ipar[22] - 1:ipar[22] + n - 2], and return the control to the dfgmres routine.
RCI_request= 4
check if the norm of the current orthogonal vector is zero, within the rounding or computational errors. Return the control to the dfgmres routine if it is not zero, otherwise complete the solution process by calling dfgmres_get routine.
