7302 Discussions
Using the scalapack and blacs MKL intel libraries without MPI
Zhanghong_T_
Dear all,
I would like to use the scalapack and blacs MKL intel libraries without MPI on multi-cores machines, the environment to build the project is:
32 bit Windows XP (or 64 bit) + VS.net2003 (or 2005, 2008) + IVF 11.0 + MKL 10.1
How can I build such a project to make use of all cores? What should I pay attention to for writting code? Could anyone give me such an example of project to show this usage?
Zhanghong Tang
Gennady_F_Intel
Hi Zhanghong, are you working on SMP or Cluster Systems?
--Gennady
Zhanghong_T_
--Gennady
Hi Gennady,
Thanks for your kindly reply. Currently working on SMP system (just 4-core intel processor, 64 bit Windows XP). I wish to use all CPUs without installing the MPI, could I link the Intel's libraries to let all CPUs be used?
Zhanghong Tang
ArturGuzik
Valued Contributor I
you don't need to do anything, I believe (if I understand your system config correctly). The MKL automatically sets number of threadsOMP_NUM_THREADS to number of cores, and you should observe 100% usage of the cores (if you have enough to work on in your app) From version 10 you have more control over this and additional MKL_NUM_THREADS. Take a look at Chapter 6, Managing performance and Memory in User's Guide.
You can paralize rest of your app using OpenMP.
A.
Edit:
I overlooked the most important part of the message ScaLAPACK. Well, so now I'm not so sure about it. Is it for testing before going to Cluster? I saw your environment posted on IVF forum. You have installed couple of things:-)
Zhanghong_T_
Quoting - ArturGuzik
A.
Edit:
Dear ArturGuzik,
Thank you so much for your kindly suggestion. I will read the document carefully.
Zhanghong Tang
