VSDIV problem.
siinii
I make a DLL(Regular dll)using a MKL and test it with Delphi interface.
The vsDiv function is used in the DLL.
When I made a test program using VC++, it worked.
but when I made a test program using Delphi, in the vsDiv, floating point division by zero error occured.
What I can't understand is the test program's formalityis same.
Test program using the VC++ is worked as normal and using the Delphi is not workd.
Could u give me a advice
Gennady_F_Intel
What is the MKL version?
How did you build the DLL?
What is the CPU type? architecture?
--Gennady
