VSL_CC_ERROR_ALLOCATION_FAILURE
Howard_Weiss
I am trying to convolve a 4094x4096 array with a 39x109 kernel using vslsconv_2d.
Example is based on example vslsconv_2d_auto.
I cannot find an explanation of what this error means and how to avoid/fix it.
Please advise.
Gennady_F_Intel
Howard,
Do you encounter the similar problem in the case of smaller input arrays?
say, 1024x1024
--Gennady
Howard_Weiss
Gennady -
Reducing the Matrix size resolved the problem
Paul_S_Intel2
I have a similar problem. I'm convoluting a 7000x7000 matrix with a 25x25 kernel. I get the -2001 error code at the vsldConvExec step (see below). When I reduce the size of the matrix to 5000x5000 everything works fine.
I changed the MKL_DISABLE_FAST_MM by typing "setenv MKL_DISABLE_FAST_MM 1" but that didn't help.
It's hard to believe that it's not possible to use a 7000x7000 matrix; something seems fishy.
Any suggestions?
Paul
status = vsldConvExec(task, dA,NULL, dR,NULL, y,NULL);
    if( status != VSL_STATUS_OK ){
        printf("ERROR: job status bad, exit with %d\n", status);
        return 1;
gives: ERROR: job status bad, exit with -2001
