7292 Discussions
What is the recommend MKL re-distrubutables we should use?
Tony_G_2
There is a list of re-distrubutable files in the redist.txt file. Should we supply ALL of these re-distributales libs to our end customer to cover all bases and a chip sets etc, since some of these are loaded at runtime (because ldd is not sufficient to determine exactly which ones are required).
OR is there some documentation what tells us what the minimum/required set is please?
For example, lets say I was only solving eigenvalue problems with MKL. Would I still need to re-distribute VML libs?
Thank you!
Tony
Gennady_F_Intel
Tony, there are two methods only : 1 - re-distrubute all files from redist.txt   2) or create custom dll ( pls refer User's Guide for details) which will contain e.x sfeast_syev() routine.
Tony_G_2
Thank you! That is very helpful!
regards,
Tony
