7303 Discussions
What performance I should expect from following code
Pouya_Z_
Consider following two part of the codes:
/* Perform LU factorization and store in DSS_handle */
for(k = 0; k  < N; k++){
gettimeofday(&stTime, NULL);
//DSS solver options
MKL_INT solOpt = (MKL_DSS_DEFAULTS | MKL_DSS_REFINEMENT_OFF) | MKL_DSS_TRANSPOSE_SOLVE;
MKL_INT nRhs = 3;
dss_solve_real(DSS_handle, solOpt, bufferRHS, nRhs, bufferX3);
dssSolCnt++;
gettimeofday(&endTime, NULL);
dssSolTime += (double)(endTime.tv_sec*1000000 + endTime.tv_usec - stTime.tv_sec*1000000 - stTime.tv_usec);
/* Do some other things */
For this code, dssSolTime, which represents the time required to performe forward and backward solutions, is 19.87sec for a 3408 * 3408 matrix.
Now, if I do the same calculations sequentially using following code,
MKL_INT nRhs = 1;
dss_solve_real(DSS_handle, solOpt, bufferRHS+numOfEqs, nRhs, bufferX3+numOfEqs);
dss_solve_real(DSS_handle, solOpt, bufferRHS+2*numOfEqs, nRhs, bufferX3+2*numOfEqs);
dssSolCnt++;
it completes the computations much faster anf dssSolTime will be 2.04sec for the matrix (almost 10 times faster when I ask dss_solve_real to solve for all righ-hand-side vectors.)
I assumed that dss_solve_real is smart enough to create three threads to solve for all right-hand side vectors simultaneously. Therefore, I expected first code to be three times faster than second code. But, the huge performance degradation implies that I may be missing something here. So, it is appreciated if you let me know whether or not dss_solve_real can solve for three right-hand-side vectors in parallel. Also, kindly let me know what I should logically expect from these codes and which one should be faster.
SergeyKostrov
Valued Contributor II
Performance of the test cases depends on an Intel instruction set selected during CPU dispatching ( mkl_core.dll -> mkl_rt.dll -> some MKL CPU dispatching DLL ). You have not provided any details about OS and hardware.
