Where does "intel_cpu_indicator" come from?
eijkhout1
Not sure if this is the right board, sorry...
I get an undefined reference and I can't figure out where it comes from:
gpas: symbol lookup error: gpas: undefined symbol: __intel_cpu_indicator
(I'm running in a batch system here on cluster)
This is about the executable:
lonestar% nm gpas | grep indicator
0842db40 B __intel_cpu_indicator
U __intel_cpu_indicator_init
Doesn't this means that the "init" routine is actually undefined? The "intel_cpu_indicator" is in some other segment which from googling I understand to be mostly about data.
Here's my link line:
mpif90 -L/opt/intel/compiler81/fc/lib ipars.o read1.o read2.o units.o comp.o table.o idata.o extvar.o memman1.o memman2.o divide.o timer.o prtout.o tdata.o stdout.o initial.o iwell.o owell.o prop.o restart.o cputime.o meminfo.o memman3.o ccallc.o xarray.o xtdata.o xisdat.o xiadat.o xstep.o xivdat.o xprop.o xsurface.o xwdata.o xstdout.o xupdate.o xflash.o aqueous.o xeos.o influid0.o eos_1ph.o rowpw.o jmass.o vis.o jaccum.o eos_jaco.o relderiv.o zderiv.o rrderiv.o ift.o mresipw.o roderiv.o eosxi2ni.o xeosbas.o jaco2pw.o jsource.o jprint.o xprint.o xquit.o xsolver.o xwell.o xtimmul.o xtrans.o jacobian.o xsolve.o xdelta.o xaqcomp.o xrelperm.o xtrapn.o xsurf.o fiats.o fiatsol1.o fiatsol2.o jimpsurf.o putil.o manyc.o manyf.o parbuf.o -o gpasv3_6 -L/opt/apps/petsc/petsc_intel_gm-2.1.6/lib/libO/linux_intel -lpetscfortran -lpetscsnes -lpetscsles -lpetscmat -lpetscvec -lpetsc -lpetscdm -L/usr/X11R6/lib -lX11 -L -lmkl_p4 -L/opt/MPI/intel8/mpich-gm/1.2.6..14/lib -lmpich -lpmpich -lpmpich -lm -L/opt/apps/petsc/petsc_intel_gm-2.1.6/lib/libO/linux_intel -lpetscgsolver -lpetscgrid -lpetscmesh -lpetscts -lpetscsnes -lpetscsles -lpetscdm -lpetscmat -lpetscvec -lpetsc -L/usr/X11R6/lib -lX11 -Wl,-rpath,/opt/intel/mkl721/lib/32 -L/opt/intel/mkl721/lib/32 -lmkl_lapack -lmkl_def -lguide -L/opt/MPI/intel8/mpich-gm/1.2.6..14/lib -lmpich -lpmpich -lpmpich
The missing item is definitely not in the mpich or petsc libraries.
Anyone any idea?
Victor
hashimoto
I had the same problem like,
when I used MKL 8.0.
But, the problem was fixed when I employed MKL 8.1.
Atsushi
TimP
The problem typically is caused by linking against an out of date set of shared libraries, such as those which come with MKL 7.2, and then attempting to run against a newer shared libraries, such as those which come with a recent Intel compiler release. MKL 8.0 had several library foul-ups, so I would agree with the other poster's advice about MKL 8.1. I hope you are using one of the latest updates, if you are still using Intel 8.1 compilers. If so, you should not set a -L path to the MKL library installation, but instead link the specific .a or .so files you want from MKL libraries, so that the linker finds the required libraries in your compiler library installation.
intel_cpu_indicator() is likely to be found in libguide.so in an out of date MKL installation, but in libirc in the compiler installation.
