7287 Discussions
Where is the value of "CblasRowMajor" set and declared in MKL tutorial sample?
zzzhhh
In the C version of MKL's tutorial, source file dgemm_example.c, line 71:
    cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans,
                m, n, p, alpha, A, p, B, n, beta, C, n);
Where is the varialble `CblasRowMajor` declared and where is the value of this variable set? I couldn't find any clue about it in the source file. Thank you for your help.
Gennady_F_Intel
These declarations you may see into header files, e.x. - mkl_cblas.h:
typedef enum {CblasRowMajor=101, CblasColMajor=102} CBLAS_LAYOUT;
Gennady_F_Intel
zzzhhh
Thank you, Gennady. I had thought it is a variable; turns out that it is an enum constant ...
