Which of libmkl_blacs_* should be use?
Sangamesh_B_
Hi all,
I've installed Intel C++ & Fortran 10.1.008 Compilers on an AMD64 opetron cluster.
MKL - 10.0.1.014 is also installed.
One of the application's makefile contains following BLACS(netlib.org) libraries :
blacsF77init_MPI-LINUX-0.a
blacs_MPI-LINUX-0.a
To replace these libraries with MKL libraries, which of the following blacs libraries to use?
libmkl_blacs_ilp64.a
libmkl_blacs_intelmpi20_ilp64.a
libmkl_blacs_intelmpi20_lp64.a
libmkl_blacs_intelmpi_ilp64.a
libmkl_blacs_intelmpi_lp64.a
libmkl_blacs_lp64.a
libmkl_blacs_openmpi_ilp64.a
libmkl_blacs_openmpi_lp64.a
Earlier I used libmkl_blacs_ilp64.a, it got compiled. While executing, it failed in the initial stage with SIGSEGV Segmentation fault + collective communication abort error. (With MPICH2-1.0.2 compiled with intel compilers)
Thanks in advance,
Sangamesh
Todd_R_Intel
The libmkl_blacs_intelmpi20_ilp64.a and libmkl_intelmpi20_lp64.a libraries are compatible with MPICH2. The User Guide is your best bet for info like this. See the detailed directory structure table in chapter 3.
Todd
