Wrong results for SpMV
jaidotsh
While doing SpMVusing MKL routines I got wrong (inaccurate) results for both COO and CSR formats. I checked it with several matrices eg:ck400. I have taken 1-based index matrices from the .mtx files. I observed that single precision results are still worse, resulting in huge numbers.
Output of y = Ax (x=1) for COO and CSR routines
0.792798
3.828488
3.575541
0.787644
2.179928
0.935596
0.826411
2.150882
1.681057
1.230554
Output of my implementation
1.594622
3.375540
2.971066
1.472197
1.733999
0.933401
0.841957
1.671079
1.527866
Why is this happening?
Thanks in advance.
Jay
mecej4
The Harwell-Boeing format stores the matrix by packing column-1, followed by packing column-2, etc, which is the traditional storage order in Fortran.
By interpreting the columns as rows, in effect you are using the transpose of the matrix, and the matrix is not symmetric. If that is what you really desire, simply change the first subroutine argument from 'T' to 'N' in my listing and you will get the results in #3.
Or, in your C code, change the first argument to 'T'.
Gennady_F_Intel
Could you please give us the example of the code which we can compile and check on our side.
There are many similar requests on mkl forum, but mostly the cause of the problem is incorrect usage ot this sort of routines.
There are numbers of examples of program for using MKL Sparse BLAS routines for matrices represented in the different sparse formats including COO and CSR.
I would recomend to see at these examples first of all.
You can find these example ( cspblas_ccoo.c cspblas_ccsr.c) < MKLROOT>\examples\spblasc\
mecej4
The results that you showed under "Output of y = Ax (x=1) for COO and CSR routines" are correct. They are what I get from the MKL call
[bash]      call mkl_scsrgemv('T',NCOL,values,colptr,rowind,x,y)
[/bash]
after reading in the matrix "ck400" using the skeleton code from
http://math.nist.gov/MatrixMarket/src/hbcode1.f
You did not say anything about "my implementation", yet you ask us to tell you what is wrong with it. Well, there are zillion ways of calling MKL (or any other library) incorrectly.
For reference, the complete code follows.
[fxfortran]      program jdotsh
implicit none
include 'mkl_spblas.fi'
integer NMAX, NNZMAX,I, LUNIT
parameter (NMAX=400, NNZMAX=2860, LUNIT=11)
! ... SAMPLE CODE FOR READING A SPARSE MATRIX IN STANDARD FORMAT
CHARACTER TITLE*72 , KEY*8 , MXTYPE*3 , &
PTRFMT*16, INDFMT*16, VALFMT*20, RHSFMT*20
INTEGER TOTCRD, PTRCRD, INDCRD, VALCRD, RHSCRD, &
NROW , NCOL , NNZERO, NELTVL
INTEGER COLPTR (NMAX+1), ROWIND (NNZMAX)
REAL VALUES (NNZMAX), X(NMAX), Y(NMAX)
! ... READ IN HEADER BLOCK
open(unit=LUNIT,file='ck400.rua',status='old')
READ ( LUNIT, 1000 ) TITLE , KEY , &
MXTYPE, NROW , NCOL , NNZERO, NELTVL, &
PTRFMT, INDFMT, VALFMT, RHSFMT
1000 FORMAT ( A72, A8,/,5I14,/ A3, 11X, 4I14,/,2A16, 2A20 )
! ... READ MATRIX STRUCTURE
READ ( LUNIT, PTRFMT ) ( COLPTR (I), I = 1, NCOL+1 )
READ ( LUNIT, INDFMT ) ( ROWIND (I), I = 1, NNZERO )
IF ( VALCRD .GT. 0 ) THEN
! ... READ MATRIX VALUES
READ ( LUNIT, VALFMT ) ( VALUES (I), I = 1, NNZERO )
ENDIF
X(1:NCOL) = 1.0
write(*,2000)y(1:10)
2000 format(1x,5ES16.7)
end program jdotsh
[/fxfortran]
jaidotsh
@mecej4
Thanks for the code. I'm not that good in fortran, anyways I have attached my MKL kernel call code with this post. Actually, I'm not supposed to disclose my implementation. But I'll show you that my results are right
When I do SpMV from ck400 matrix I get these results
Eg: First row
[bash]1 1  4.5988460100000e-01
2 1  3.6284045000000e-02
5 1  1.0781816600000e+00
6 1  2.8797109600000e-02
203 1 -8.6315697400000e-03
204 1  1.0598980300000e-04[/bash]
[bash]0.459+0.0036+1.07+0.028-0.0086+0.00010 = 1.594622[/bash]
Fourth row
[bash]3 4 -2.4700304700000e-02
4 4  4.4020096400000e-01
7 4 -1.2549445700000e-02
8 4  1.0782397800000e+00
201 4 -1.0598980300000e-04
202 4 -8.8883786800000e-03
[/bash]
[bash]-0.024+0.44-0.012+1.07-0.00010-0.0088 = 1.472197[/bash]
which is same as the results of my implementation
@Fedorov I'll have a look at it. I've attached the routine calling codes.
mecej4
jaidotsh
@mecej4 Thanks a lot, it worked. @Fedorov So true!
jaidotsh
I'm stuck with another problem!!. When I give matrices like ck400,pwtk
But, when I give consph, rma10I get a segmentation fault. I've thoroughly checked the indices from the
file, I still can't find the error!
Thanks in advance!
