7300 Discussions
Wrong results while solving for eign vectors!
psing51
i am trying to use the dsyev routine. Now i modified your default example slightly by solving for matrix:
2,1,3,
1,2,3,
3,3,20
i am getting :
Eigenvalues
   1.00   2.00  21.00
Eigenvectors (stored columnwise)
   0.71   0.69   0.16
  -0.71   0.69   0.16
   0.00  -0.23   0.97
i again tried with vector:
1,2
2,1
 Eigenvalues
  -1.00   3.00
  -0.71   0.71
   0.71   0.71
eign values are fine , but why eign vectors are wrong !
according to this and this the eign vectors should have been :
[-1 , 1 , 0] , [-3,-3,1] , [1,1,6]
and [1,-1] , [1,1]
*  Copyright (C) 2009-2015 Intel Corporation. All Rights Reserved.
*  The information and material ("Material") provided below is owned by Intel
*  Corporation or its suppliers or licensors, and title to such Material remains
*  with Intel Corporation or its suppliers or licensors. The Material contains
*  proprietary information of Intel or its suppliers and licensors. The Material
*  is protected by worldwide copyright laws and treaty provisions. No part of
*  the Material may be copied, reproduced, published, uploaded, posted,
*  transmitted, or distributed in any way without Intel's prior express written
*  permission. No license under any patent, copyright or other intellectual
*  property rights in the Material is granted to or conferred upon you, either
*  expressly, by implication, inducement, estoppel or otherwise. Any license
*  under such intellectual property rights must be express and approved by Intel
*  in writing.
   LAPACKE_dsyev Example.
   Program computes all eigenvalues and eigenvectors of a real symmetric
   matrix A:
     1.96  -6.49  -0.47  -7.20  -0.65
    -6.49   3.80  -6.39   1.50  -6.34
    -0.47  -6.39   4.17  -1.51   2.67
    -7.20   1.50  -1.51   5.70   1.80
    -0.65  -6.34   2.67   1.80  -7.10
   Description.
   The routine computes all eigenvalues and, optionally, eigenvectors of an
   n-by-n real symmetric matrix A. The eigenvector v(j) of A satisfies
   A*v(j) = lambda(j)*v(j)
   where lambda(j) is its eigenvalue. The computed eigenvectors are
   orthonormal.
   Example Program Results.
 LAPACKE_dsyev (row-major, high-level) Example Program Results
 Eigenvalues
 -11.07  -6.23   0.86   8.87  16.09
  -0.30  -0.61   0.40  -0.37   0.49
  -0.51  -0.29  -0.41  -0.36  -0.61
  -0.08  -0.38  -0.66   0.50   0.40
   0.00  -0.45   0.46   0.62  -0.46
  -0.80   0.45   0.17   0.31   0.16
#include <stdlib.h>
#include <stdio.h>
#include "mkl_lapacke.h"
/* Auxiliary routines prototypes */
extern void print_matrix( char* desc, MKL_INT m, MKL_INT n, double* a, MKL_INT lda );
/* Parameters */
#define N 2
#define LDA N
/* Main program */
int main() {
        /* Locals */
        MKL_INT n = N, lda = LDA, info;
        /* Local arrays */
        double w;
        double a[LDA*N] = {
		1,2,
		2,1
        /* Executable statements */
        printf( "LAPACKE_dsyev (row-major, high-level) Example Program Results\n" );
        /* Solve eigenproblem */
        info = LAPACKE_dsyev( LAPACK_ROW_MAJOR, 'V', 'U', n, a, lda, w );
        /* Check for convergence */
        if( info > 0 ) {
                printf( "The algorithm failed to compute eigenvalues.\n" );
                exit( 1 );
        /* Print eigenvalues */
        print_matrix( "Eigenvalues", 1, n, w, 1 );
        /* Print eigenvectors */
        print_matrix( "Eigenvectors (stored columnwise)", n, n, a, lda );
        exit( 0 );
} /* End of LAPACKE_dsyev Example */
/* Auxiliary routine: printing a matrix */
void print_matrix( char* desc, MKL_INT m, MKL_INT n, double* a, MKL_INT lda ) {
        MKL_INT i, j;
        printf( "\n %s\n", desc );
        for( i = 0; i < m; i++ ) {
                for( j = 0; j < n; j++ ) printf( " %6.2f", a[i*lda+j] );
                printf( "\n" );
mecej4
Please define "wrong eigenvector". Did you forget that if A.x = λx, it is also true that A.y = λy, where y = c.x, with c a scalar multiplier? The eigenvectors (that you reported as those that were given by Lapack) happen to be scaled so that they have norm = 1, but other choices are equally valid.
