7298 Discussions
Wrong solution computed by distributed PARDISO with 0-based indexed BSR matrix
asd__asdqwe
I'm attaching two .c files that should compute the solution of the linear system Ax = b, with
A = [1, -3, 5, 1;
-1, -2, 6, 10;
4, -4, 7, -5;
4, 2, 8, -1];
and
b = [1;1;0.75;1]
The solution given by MATLAB is the same as with the file cl_solver_unsym_distr_1.c, i.e.,
x =
   -1.0000
    0.1500
    0.5500
   -0.3000
With cl_solver_unsym_distr_0.c, I get a completly wrong solution: x = [-0.031169, -0.036084, 0.139033, 0.026384]'
Moreover, at the beginning of the execution, I get the following output:
1-based array indexing is turned ON
which is wrong, since I'm setting iparm[34] to 1.
Can you reproduce this issue? How can I fix it? I'm compiling the examples with the following command: make sointel64 mpi=mpich2 compiler=intel (inside the folder /opt/intel/mkl/examples/cluster_sparse_solverc of MKL 11.3.3)
asd__asdqwe
Is this fixed in the upcoming update? Thank you in advance for an answer.
asd__asdqwe
With the latest MKL from m_ccompxe_2017.0.036.dmg, I now have the following error with these scripts:
Fatal error in MPI_Reduce: Invalid count, error stack:
MPI_Reduce(1258): MPI_Reduce(sbuf=0x7fbae3700500, rbuf=0x7fbae3607500, count=-16380, MPI_DOUBLE, MPI_SUM, root=0, comm=0x84000004) failed
MPI_Reduce(1167): Negative count, value is -16380
Do you have a fix? Thanks.
Gennady_F_Intel
Actually, this issue is targeted to be fixed in MKL 2017 update 1. We will keep you updated with the status of this issue.
Gennady_F_Intel
MKL 2017 update 1 has been recently released. Could  you please check if the problem is still there and let us know! regards.
asd__asdqwe
The problem is still there, I still get a completely wrong solution with the 0-based approach:
The solution of the system is:
 on zero process x [0] = -0.031169
 on zero process x [1] = -0.036084
 on first process x [0] =  0.139033
 on first process x [1] =  0.026384
With the 1-based approach, I still get the correct solution:
 on zero process x [0] = -1.000000
 on zero process x [1] =  0.150000
 on first process x [0] =  0.550000
 on first process x [1] = -0.300000
Can you fix this please? Thanks.
asd__asdqwe
Can you reproduce this issue? Thank you.
Gennady_F_Intel
yes, we have to confirm the issue still exists with version 2017 u1.
Gennady_F_Intel
Dear users, please accept our apologize for the wrong message regard to the previous message about the fix of this issue in MKL 2017 u1. Actually the fix of this issue will be available into MKL 2017 update 2. Regards, Gennady
Gennady_F_Intel
MKL 2017 update 2 is released a few days ago. Could you please check the problem with this update and keep us inform the status.
