/Zi makes MKL slow on Windows.
erling_andersen
I have a Windows application I build with Intel C 18.0.2 that calls MKL extensively. I want to profile it with Vtune.
If I build it with the /Zi optimization i.e. debug info. needed for profiling it seems to get 5 times slower when run as stand alone from the command line. Vtune tells me that much time is spend in dgemm. Could it add a fixed overhead per dgemm call?
How come? Any suggestions?
Erling
Gennady_F_Intel
This is an unexpected case. We expect to see the same mkl performance with and without debug optimization. You may try to measure mkl's ( dgemm in your case ) function performance
double t1 = dsecnd()
        frot( i=0< m; ++i) dgemm();
double t2 = dsecnd()
and make some conclusion
