apt repository broken
JMart62
Dear all,
I get the following errors in Ubuntu 18.04 when running
wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
wget https://apt.repos.intel.com/setup/intelproducts.list -O /etc/apt/sources.list.d/intelproducts.list
# The previous three work without problems, but the following line has the issue:
apt-get update && apt-get install -y --no-install-recommends intel-mkl-64bit-2018.3
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Get:4 https://apt.repos.intel.com/intelpython binary/ InRelease [1403 B]
Get:5 https://apt.repos.intel.com/mkl all InRelease [4422 B]
Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:7 https://apt.repos.intel.com/ipp all InRelease [4416 B]
Get:8 https://apt.repos.intel.com/tbb all InRelease [4400 B]
Get:9 https://apt.repos.intel.com/daal all InRelease [4414 B]
Get:10 https://apt.repos.intel.com/mpi all InRelease [4358 B]
Get:11 https://apt.repos.intel.com/intelpython binary/ Packages [1853 B]
Get:12 https://apt.repos.intel.com/mkl all/main amd64 Packages [39.3 kB]
Err:12 https://apt.repos.intel.com/mkl all/main amd64 Packages
  File has unexpected size (45690 != 39339). Mirror sync in progress? [IP: 23.67.128.143 443]
  Hashes of expected file:
   - Filesize:39339 [weak]
   - SHA512:6c55f783460cb6b09e2006fd85ad9c10d9abb0226de4f96d2c2ee3558ce3b593ddaa470170dfde7187271bbeae2f843e5bacce4095f7cb2ac0adac853096f99b
   - SHA256:0ecd4a8ec38322c936789aefd423fd0c562aa2088a0baa20b0cabc7824f9032e
   - SHA1:aa20c4f4f9944676a1421c22b794cde84b054ee2 [weak]
   - MD5Sum:439ae5cfb5a4584eeaec01f13f2acc63 [weak]
  Release file created at: Thu, 15 Mar 2018 11:31:06 +0000
Get:13 https://apt.repos.intel.com/mkl all/main all Packages [13.0 kB]
Err:13 https://apt.repos.intel.com/mkl all/main all Packages
Get:14 https://apt.repos.intel.com/ipp all/main all Packages [6740 B]
Get:15 https://apt.repos.intel.com/ipp all/main amd64 Packages [18.0 kB]
Get:16 https://apt.repos.intel.com/tbb all/main all Packages [5967 B]
Get:17 https://apt.repos.intel.com/tbb all/main amd64 Packages [8200 B]
Get:18 https://apt.repos.intel.com/daal all/main all Packages [6028 B]
Get:19 https://apt.repos.intel.com/daal all/main amd64 Packages [10.5 kB]
Get:20 https://apt.repos.intel.com/mpi all/main all Packages [791 B]
Get:21 https://apt.repos.intel.com/mpi all/main amd64 Packages [1725 B]
Fetched 83.3 kB in 2s (53.7 kB/s)
Reading package lists... Done
W: Conflicting distribution: https://apt.repos.intel.com/intelpython binary/ InRelease (expected binary/ but got )
E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-amd64/Packages.gz ; File has unexpected size (45690 != 39339). Mirror sync in progress? [IP: 23.67.128.143 443]
E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-all/Packages.gz
E: Some index files failed to download. They have been ignored, or old ones used instead.
It worked multiple times on Sunday, but that was still 2018.2, and it worked once today for 2018.3, but failed about 5 times today already. It appears as if one mirror is ok and another is in a broken state. Can anyone confirm this? Any ideas how to resolve this?
Thanks and best regards,
Jonathan
Ying_H_Intel
Hi Jonathan,
​Thank you for your report.  I will escalate to the deployment team and see if they have any suggestion.
I guess,  as we are deploying MKL 2018 u3 recently (the MKL 2018 u3 was done in APT 2 days ago), which may bring unstable status of the servers.
​Ying
Simpson__Adam
I am also experiencing this issue on Ubuntu/16.04.
I believe that https://apt.repos.intel.com/mkl/dists/all/InRelease has the wrong file size(and hashes) for the index file "main/binary-amd64/Packages". Perhaps this wasn't updated when the repo got updated for MKL 2018 u3?
Any help fixing this would be much appreciated!
JMart62
Thanks a lot, Ying!
Just to keep you updated and help with the bug hunt: Today, I got the same error with a different IP address (see below).
Best,
Jonathan
Err:20 https://apt.repos.intel.com/mpi all/main all Packages
  File has unexpected size (1251 != 791). Mirror sync in progress? [IP: 95.100.64.47 443]
   - Filesize:791 [weak]
   - SHA512:6aaecc1992db6f76c9de16aafd840f00dc89da624d21049ba02cfd08456b5d1bd38264b9060944ad274fdacc34888cf7e4a74d060d08dba53926370e85fcd201
   - SHA256:5459864e393a1b57efac83ccd402ce640ccc8f31349000cc119856eab32fd408
   - SHA1:f0926bd401a45dc40f7e2d09f5e866ca694d518a [weak]
   - MD5Sum:5dd7837d013b0f7b6e44f29acd520840 [weak]
  Release file created at: Thu, 15 Mar 2018 10:46:54 +0000
Err:21 https://apt.repos.intel.com/mpi all/main amd64 Packages
Fetched 141 kB in 4s (32.1 kB/s)
E: Failed to fetch https://apt.repos.intel.com/mpi/dists/all/main/binary-all/Packages.gz ; File has unexpected size (1251 != 791). Mirror sync in progress? [IP: 95.100.64.47 443]
E: Failed to fetch https://apt.repos.intel.com/mpi/dists/all/main/binary-amd64/Packages.gz
Ying_H_Intel
Hi Jonathan, Adam,
The problem was escalated to our repository administrator.  They replied , thank you reports!  they already purged caches for the files, the files should be accessible and downloadable.  Please let me know if you have any result.
​Ying
Wink__Alle_Meije
I have the same problem on  my Debian (stretch) system, getting a warning only from the intelpython repo.
In the file /etc/apt/sources.list.d/intelproducts.list I have
deb https://apt.repos.intel.com/intelpython binary/
deb https://apt.repos.intel.com/mkl all main
deb https://apt.repos.intel.com/ipp all main
deb https://apt.repos.intel.com/tbb all main
deb https://apt.repos.intel.com/daal all main
deb https://apt.repos.intel.com/mpi all main
and after each apt update I get the warning
Is it possible to fix the warning?
Thanks!
chat__pil
I am still experiencing the same problem as Jonathan. Please fix this soon.
Thanks in advance
Kopylov__Yevhen
I have the same problem on my Ubuntu 16.04.4 E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-amd64/Packages ; Writing more data than expected (241534 > 239155)
Nottingham__Chris
I am having problems to, i.e.,
sudo apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB
sudo sh -c 'echo deb https://apt.repos.intel.com/mkl all main > /etc/apt/sources.list.d/intel-mkl.list'
sudo apt-get update
Hit:1 http://nz.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://nz.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://nz.archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:4 https://apt.repos.intel.com/mkl all InRelease [4,422 B]
Get:5 https://apt.repos.intel.com/mkl all/main i386 Packages [16.8 kB]
Err:5 https://apt.repos.intel.com/mkl all/main i386 Packages
  File has unexpected size (18205 != 16822). Mirror sync in progress? [IP: 184.27.92.21 443]
   - Filesize:16822 [weak]
   - SHA512:fc0747fbdbf998b6acfd02847f0439c5704ac74371b0551a3d7dda93a33922b65a0f1c00cc4a7b7ec530e3cb238fc05cb61ccefe3f18da314e1556f72ba4b790
   - SHA256:26e462b4fa2ee9c6600b8681d0a0524d32a6c16d0d7eefa039ddc72054310132
   - SHA1:c341b78c41120b141bb37d34eb295709290f4dcd [weak]
   - MD5Sum:843f99b2d39625e02a4e08ae525400d2 [weak]
  Release file created at: Tue, 15 May 2018 15:47:25 +0000
Hit:6 http://security.ubuntu.com/ubuntu bionic-security InRelease
Get:7 https://apt.repos.intel.com/mkl all/main all Packages [12.6 kB]
Err:7 https://apt.repos.intel.com/mkl all/main all Packages
Get:8 https://apt.repos.intel.com/mkl all/main amd64 Packages [36.6 kB]
Err:8 https://apt.repos.intel.com/mkl all/main amd64 Packages
Fetched 4,422 B in 1s (5,648 B/s)
E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-i386/Packages.bz2  File has unexpected size (18205 != 16822). Mirror sync in progress? [IP: 184.27.92.21 443]
E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-all/Packages.bz2
E: Failed to fetch https://apt.repos.intel.com/mkl/dists/all/main/binary-amd64/Packages.bz2
chris@chris-desktop:~$ sudo apt-get install intel-mkl-2019.0-045
Building dependency tree
Reading state information... Done
E: Unable to locate package intel-mkl-2019.0-045
E: Couldn't find any package by glob 'intel-mkl-2019.0-045'
E: Couldn't find any package by regex 'intel-mkl-2019.0-045'
Note, issues occurring on both 16.04 and 18.04
degraca__arom
Hello, I can also confirm that I'm experiencing this problem as well. I use mkl to within docker and in order for my unit tests to be run with travis and appveyor I install mkl via apt.
Please notice Err 21 and Err 23 in the screen shot.
I would also like to add that the problem seems upstream because I can't even see mkl in the apt-cache as a result of:
apt-cache search mkl
Please fix this promptly, I'm using mkl for my undergraduate senior thesis and until the upstream is fix my build is quite hacky.
(Edit) In order to cleanly demonstrate the problem, Here is a  Dockerfile which cleanly demonstrates the problem.
#DOCKER FILE BEGIN
# Ubuntu Dockerfile
# https://github.com/dockerfile/ubuntu
# Pull base image.
FROM ubuntu:18.04
# Install.
RUN \
  sed -i 's/# \(.*multiverse$\)/\1/g' /etc/apt/sources.list && \
  apt-get update && \
  apt-get -y upgrade && \
  apt-get install -y build-essential && \
  apt-get install -y software-properties-common && \
  apt-get install -y byobu curl wget && \
  #mkl install begins here
  wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB && \
  apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS-2019.PUB && \
  sh -c 'echo deb https://apt.repos.intel.com/mkl all main > /etc/apt/sources.list.d/intel-mkl.list' && \
  apt-get -y update && \
  #mkl install ends here
  rm -rf /var/lib/apt/lists/*
# Add files.
ADD root/.bashrc /root/.bashrc
ADD root/.gitconfig /root/.gitconfig
ADD root/.scripts /root/.scripts
# Set environment variables.
ENV HOME /root
# Define working directory.
WORKDIR /root
# Define default command.
CMD ["bash"]
#DOCKER FILE END
Ying_H_Intel
Dear Chirs and Arom,
Thank you everyone for the report.  we escalate the issue to our install team. we suppose to fix it as soon as possible and update you if any news.
​Ying
Ying_H_Intel
Dear All,
​Our internal support team  fix the problem.   there is a issue in our deploy system.  it should be no more problems in future.
Thank you much for the report!
Ying
Loller96
Hi, I face the same issue right now:
Err:7 https://apt.repos.intel.com/oneapi all/main amd64 Packages
 File has unexpected size (97059 != 123241). Mirror sync in progress? [IP: 23.9.11.90 443]
  - Filesize:123241 [weak]
  - SHA512:ce504506c37bdca5151d49d299ff15e33deebcbece068139f699d1f7a6e25bae873b10bd177f823e9fb357ac9d18a4cd0dce6be254567418a1f0aed5b356382c
  - SHA256:b4d3fa20a44464bc978fa6f49cfd7c6aa30635972468ea383bf2e79d6107485d
  - SHA1:7fea77a5124d63b2c836c384bb5f59a05cc46072 [weak]
  - MD5Sum:858168f2c4ce6460d683c63b33501304 [weak]
 Release file created at: Wed, 29 Sep 2021 08:17:36 +0000
Fetched 354 kB in 1s (415 kB/s)
E: Failed to fetch https://apt.repos.intel.com/oneapi/dists/all/main/binary-amd64/Packages.gz  File has unexpected size (97059 != 123241). Mirror sync
