array overlap in OneMKL BLAS routines
vahidmech1
In LAPACK documentation, it is noted that "Different arrays used as parameters to oneMKL LAPACK routines must not overlap." (https://spec.oneapi.io/versions/latest/elements/oneMKL/source/domains/lapack/lapack.html) but what about BLAS routines. Could the arrays overlap in BLAS routines or not?
Thank you
Gennady_F_Intel
The same with BLAS routines. We will add the same Note to the next version of oneMKL Developer Reference.
