beta distribution and MKL
jaureus
Hello, I am attempting to work with the MKL library and in particular the beta function. The commands worked with an older version of mkl on a different system. I think that there may be a problem with my function
I am calling the following subroutine:
subroutine beta_rng_mkl(seed_in, n_rand_obs_in, r_beta_list, shape1, shape2)
use :: mkl_vsl_type
integer :: brng
integer, intent(in) :: seed_in, n_rand_obs_in, methodrng
real, pointer, intent(out) :: r_beta_list
type(VSL_STREAM_STATE) :: stream
integer :: status
external :: vslnewstream, vsrngbeta, vsldeletestream
methodrng = VSL_METHOD_SBETA_CJA
brng = vsl_brng_mcg31
status = vslnewstream(stream, brng, seed_in)
status = vsrngbeta( methodrng, stream, n_rand_obs_in, r_beta_list, shape1, shape2, 0.0, 1.0 )
status = vsldeletestream(stream)
end subroutine
and I get the following error message in my program:
jgold@clinic:~/smwcv/error_infect/data_augment/random_sim/sim1/o1newinfections75$ ifort -free -O2 -stand f03 -check bounds -traceback -warn all -fstack-protector -assume protect_parens -implicitnone -o mcmcobsgammanoepsilon.out mcmcobsgammanoepsilon.f90 -I/opt/intel/composer_xe_2011_sp1.6.233/mkl/include -L/opt/intel/composer_xe_2011_sp1.6.233/mkl/lib/intel64 -lmkl_rt
mcmcobsgammanoepsilon.f90(59): error #8000: There is a conflict between local interface block and external interface block. [R_BETA_LIST]
mcmcobsgammanoepsilon.f90(367): error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [R_BETA_LIST]
call beta_rng_mkl(seed_in, n_rand_obs_in, r_beta_list, shape1, shape2)
below is the local interface:
include "mkl_vsl.f90"
module randvariables
real :: harvest, shape1, shape2
integer :: seed_in, n_rand_obs_in
real, dimension(:), pointer :: r_beta_list
integer :: r_beta_count, rejectflag
integer, dimension (:, :) , allocatable :: link
end module
program mcnet
! Tell the main program to use the randvariables module
use :: randvariables
mecej4
Detection of perceived/actual mismatches of variable types is quite context dependent. We cannot ascertain what the compiler is complaining about from the snippets of code that you showed. For example, the error messages refer to source lines 59 and 367, and we do not know what those lines contain.
Please provide a complete example that reproduces the problem.
Andrey_N_Intel
Please, provide a test casewhich reproduces the issue and would help toclarifyreasonsof thaterror.
Andrey
jaureus
here is a test program
include 'mkl_vsl.f90'
end module
program mcnet
implicit none
real :: theta
interface
implicit none
real, dimension(:), intent(out) :: r_beta_list
real, intent(in) :: shape1, shape2
end subroutine beta_rng_mkl
end interface
call random_number(harvest)
seed_in = aint(harvest * 2.0e0**31)
shape1 = 200
shape2 = 400
! print *, "shape1 ", " shape2"
! print *, shape1, shape2
n_rand_obs_in = 1
allocate (r_beta_list(n_rand_obs_in))
theta = r_beta_list(1)
print *, theta
end program
My routine is above and again here are the errors
betaworkedex.f90(20): error #8000: There is a conflict between local interface block and external interface block. [R_BETA_LIST]
betaworkedex.f90(40): error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [R_BETA_LIST]
mecej4
The subroutine that you gave in the initial post is not quite correct. It declares intent for methodrng, which is not a subroutine argument.
After declaring methodrng as a local integer variable, I obtained the following output:
[bash]T:> ifort /Qmkl mklvsl.f90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.1.3.300 Build 20120130 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. Microsoft Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:mklvsl.exe -subsystem:console -libpath:c:LANGIntelCOMPOS~2mkllibia32 mklvsl.obj T:>mklvsl 0.2999528
However, this may be a bogus result, since I did not check whether the VSL subroutine/function calls are being made with the proper argument types.[/bash]
jaureus
Hi, ok so I modified the variable definition and I get the same error. Clearly, I am doing somethng very wrong. could it have to do with the fact that I am defining variables in a module and also reading them in with an intent statement. Usually, I would not do this but it seems that this is what mkl modules want.
use :: mkl_vsl_type
integer :: brng
!integer, intent(in) :: methodrng
integer :: status, methodrng
end subroutine
mecej4
You have to add
use MKL_VSL
to provide the compiler with the information needed to check that you are making proper calls to the VSL routine(s).
There are example source codes provided with MKL, and many of these are also described in the documentation. I suggest that you pick one that is suitable, verify that it works correctly when compiled and run, and then modify the example for your purposes.
Naveen_G_Intel
Hi jaureus,
I used test case which you provided not able to reproduce it for above mentioned error, did you verified MKL_VSL option?
Naveen Gv
jaureus
Hi Naveen,
I am really sorry to say that even with all of your help I am unble to get it to work. I have tried out the example within the example set and it works so there is clearly a coding issue, however, I just can't see it.
subroutine beta_rng_mkl(seed_in, r_beta_list, shape1, shape2)
use mkl_vsl_type
use mkl_vsl
integer :: brng
real, intent(out) :: r_beta_list(1)
integer :: status, methodrng, n_rand_obs_in
!external :: vslnewstream, vsrngbeta, vsldeletestream
n_rand_obs_in = 1
end subroutine
I have modified the code to include the mkl_vsl option as suggested. However, alas still no joy. i.e. I still get the following errors with my test code:
betaworkedexold.f90(20): error #8000: There is a conflict between local interface block and external interface block. [R_BETA_LIST]
betaworkedexold.f90(41): error #6634: The shape matching rules of actual arguments and dummy arguments have been violated. [R_BETA_LIST]
Naveen_G_Intel
Test code which you provided may not be enough to reproduce the problem.
This particular error usually means that the declaration of the named routine R_BETA_LIST is different between the actual procedure and a definition that came from a module. It may be that a Build > Rebuild of the VS solution will take care of it, as sometimes, with /warn:interface enabled, a generated interface module from a previous compilation is out of date.
Naveen Gv
