bug when used openmp
nvarini
Dear all, I found a bug with mkl openmp on DSYEV. My code read a matrix of 250x250 and perform a dsyev on it. I print out the eigenvectors and eigenvalues and there are difference in the eigenvector when I use 1, 2, 4 and 8 threads.
I compile with this command:
ifort -openmp -o prova prova.f90 -Wl,--start-group $MKL_LIB/libmkl_intel_lp64.a $MKL_LIB/libmkl_intel_thread.a $MKL_LIB/libmkl_core.a -Wl,--end-group
It's possible to fix this bug?
Best regard
Nicola
Gennady_F_Intel
Nikola,
what magnitude of these differences?
--Gennady
nvarini
Hi Gennady, this is the first two eigenvector with 1 thread
5.206780874519512E-003 -2.512377498876253E-003 -0.560713995878056
-6.678309445599694E-002 1.730343130346750E-003 8.894833897540037E-002
while with 2 thread the first two eigenvector are
-3.956413109619314E-002 -8.250475621178963E-003 -0.514086076699900
-0.128043245900761 1.957126952260208E-002 7.716034330953539E-002
whit 4 thread
-3.923533964555784E-002 -8.579275778466389E-003 -0.514086076699883
-0.128043245900755 1.957126952259620E-002 7.716034330954206E-002
with 8 thread
--Nicola
Gennady_F_Intel
Hi Nicola,
Thanks for the update. If I am not mistaken, we had the similar problem in one of MKL 10.2 Update 2.
What MKL version you are using?
--Gennady
nvarini
In fact I use mkl 10.2.2, there are some patch for this problem?
Nicola
Gennady_F_Intel
yes, the latest Update 5 will be available soon, but you cancheck this problem with Update 3 or 4.
Please see here the list of fixed errors. See Update 3:
DPD200141616
Eigenvector bug in multi-threaded code of ?STEQR
