can't install, FLEXlm error
liangmz
I copied the install CD to disk and run the install. Got this error after I input the serial:
A valid FLEXlm license is required to install this product, but none were found in
/home/tools/intel_mkl_linux_10.0/instman
/opt/intel/licenses
Where is a valid FLEXlm license for this product?
any ideas?
OS: Linux bog 2.6.18-8.el5 64bit Red Hat Enterprise Linux Server release 5
attached is the installation log file
thx
mike
Wed 11 21:23:11 shell.c:29 runShellCmd():Interpreter: 'sh'
Wed 11 21:23:11 shell.c:35 runShellCmd():Command to execute: 'which rpm &>/dev/null'
Wed 11 21:23:11 shell.c:119 runShellCmd():waitpid() status for the executed command: 0
Wed 11 21:23:11 shell.c:35 runShellCmd():Command to execute: ' INSTALLEDRPM=''; INSTALLEDRPM=$(rpm -qa 2>/dev/null | grep intel-mkl); rc=$?; if [ "x$(echo $INSTALLEDRPM | grep intel)" != "x" ] && [ "$rc" == "0" ] ; then echo "The following versions of Intel Math Kernel Library and related products are installed."; rpm -q $INSTALLEDRPM --qf " - %{summary}\n"; fi'
Wed 11 21:23:12 shell.c:29 runShellCmd():Interpreter: 'sh'
Wed 11 21:23:12 shell.c:35 runShellCmd():Command to execute: 'uname -m 2>/dev/null'
Wed 11 21:23:12 shell.c:76 runShellCmd():Capturing STDOUT
Wed 11 21:23:12 shell.c:89 runShellCmd():GOT 7 bytes from STDOUT
Wed 11 21:23:12 shell.c:119 runShellCmd():waitpid() status for the executed command: 0
Wed 11 21:23:12 install.c:347 main():extract_to("zchklic86_64","/tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e",(char **)0xdb477c18,"x32",0,643024)
Wed 11 21:23:12 extract.c:165 direct_extract_to():Seeking to RPMSIZE[8]=216948521
Wed 11 21:23:12 check_license.c:126 get_full_path():getting full path for /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e
Wed 11 21:23:12 check_license.c:138 get_full_path():full path for /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e is /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e
Wed 11 21:23:12 check_license.c:534 check_license_directory():Looking for valid FLEXlm licenses under the directory /home/tools/intel_mkl_linux_10.0/instman
Wed 11 21:23:12 check_license.c:566 check_license_directory():Didn't found valid FLEXlm license in the directory /home/tools/intel_mkl_linux_10.0/instman
Wed 11 21:23:12 check_license.c:126 get_full_path():getting full path for /home/tools/intel_mkl_linux_10.0/instman/..
Wed 11 21:23:12 check_license.c:138 get_full_path():full path for /home/tools/intel_mkl_linux_10.0/instman/.. is /home/tools/intel_mkl_linux_10.0
Wed 11 21:23:12 check_license.c:676 check_license():Looking for valid licenses into the INTEL_LICENSE_FILE=(null)
Wed 11 21:23:12 check_license.c:534 check_license_directory():Looking for valid FLEXlm licenses under the directory /opt/intel/licenses
Wed 11 21:23:12 check_license.c:98 determineFLEXLM_platform():Trying to determine FLEXlm platform for machine name x86_64
Wed 11 21:23:12 check_license.c:448 check_license_file():Checking file /opt/intel/licenses/l_mkl_XZ98TXGF.lic for valid FLEXlm license
Wed 11 21:23:12 check_license.c:449 check_license_file():runpath /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e
Wed 11 21:23:12 check_license.c:450 check_license_file():-a -q
Wed 11 21:23:12 check_license.c:451 check_license_file():chklic_f_opt -fMKernL -fMKern -fCLMKernL -fCLMKern
Wed 11 21:23:12 check_license.c:452 check_license_file():chklic_c_opt -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic"
Wed 11 21:23:12 check_license.c:453 check_license_file():chklic_p_opt -pi86_r -pi86_re -pit64_lr -pit64_re
Wed 11 21:23:12 check_license.c:282 call_flexlm_chklic():Call a /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null command.
Wed 11 21:23:12 shell.c:35 runShellCmd():Command to execute: '/tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null'
Wed 11 21:23:12 shell.c:119 runShellCmd():waitpid() status for the executed command: 512
Wed 11 21:23:12 check_license.c:288 call_flexlm_chklic():Chklic value 2
Wed 11 21:23:12 check_license.c:455 check_license_file():Chklic ret value is 2
Wed 11 21:23:12 check_license.c:167 chklic_evaluate():Expired FLEXlm license was found in /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:12 check_license.c:457 check_license_file():Chklic auth value is 0
Wed 11 21:23:12 check_license.c:566 check_license_directory():Didn't found valid FLEXlm license in the directory /opt/intel/licenses
Wed 11 21:23:12 check_license.c:757 check_license():Asking user to specifiy the directory to look for valid FLEXlm license
Wed 11 21:23:12 silent_install_support.c:116 getQuestionIndex():index for the question 'FLEXLM_LICENSE_LOCATION' is 1
Wed 11 21:23:12 silent_install_support.c:23 setDefaultAnswer():last default answer is set to ''
Wed 11 21:23:12 silent_install_support.c:47 getUserAnswer():getting user answer on the question with id=FLEXLM_LICENSE_LOCATION
Wed 11 21:23:21 check_license.c:199 get_user_location():User has entered the location for FLEXlm license: /opt/intel/licenses
Wed 11 21:23:21 check_license.c:126 get_full_path():getting full path for /opt/intel/licenses
Wed 11 21:23:21 check_license.c:138 get_full_path():full path for /opt/intel/licenses is /opt/intel/licenses
Wed 11 21:23:21 check_license.c:760 check_license():Looking for valid FLEXlm license into the user-specified directory /opt/intel/licenses
Wed 11 21:23:21 check_license.c:534 check_license_directory():Looking for valid FLEXlm licenses under the directory /opt/intel/licenses
Wed 11 21:23:21 shell.c:29 runShellCmd():Interpreter: 'sh'
Wed 11 21:23:21 shell.c:35 runShellCmd():Command to execute: 'uname -m 2>/dev/null'
Wed 11 21:23:21 shell.c:76 runShellCmd():Capturing STDOUT
Wed 11 21:23:21 shell.c:89 runShellCmd():GOT 7 bytes from STDOUT
Wed 11 21:23:21 shell.c:119 runShellCmd():waitpid() status for the executed command: 0
Wed 11 21:23:21 check_license.c:98 determineFLEXLM_platform():Trying to determine FLEXlm platform for machine name x86_64
Wed 11 21:23:21 check_license.c:448 check_license_file():Checking file /opt/intel/licenses/l_mkl_XZ98TXGF.lic for valid FLEXlm license
Wed 11 21:23:21 check_license.c:449 check_license_file():runpath /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e
Wed 11 21:23:21 check_license.c:450 check_license_file():-a -q
Wed 11 21:23:21 check_license.c:451 check_license_file():chklic_f_opt -fMKernL -fMKern -fCLMKernL -fCLMKern
Wed 11 21:23:21 check_license.c:452 check_license_file():chklic_c_opt -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic"
Wed 11 21:23:21 check_license.c:453 check_license_file():chklic_p_opt -pi86_r -pi86_re -pit64_lr -pit64_re
Wed 11 21:23:21 check_license.c:282 call_flexlm_chklic():Call a /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null command.
Wed 11 21:23:21 shell.c:35 runShellCmd():Command to execute: '/tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null'
Wed 11 21:23:21 shell.c:119 runShellCmd():waitpid() status for the executed command: 512
Wed 11 21:23:21 check_license.c:288 call_flexlm_chklic():Chklic value 2
Wed 11 21:23:21 check_license.c:455 check_license_file():Chklic ret value is 2
Wed 11 21:23:21 check_license.c:167 chklic_evaluate():Expired FLEXlm license was found in /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:21 check_license.c:457 check_license_file():Chklic auth value is 0
Wed 11 21:23:21 check_license.c:566 check_license_directory():Didn't found valid FLEXlm license in the directory /opt/intel/licenses
Wed 11 21:23:21 check_license.c:757 check_license():Asking user to specifiy the directory to look for valid FLEXlm license
Wed 11 21:23:21 silent_install_support.c:116 getQuestionIndex():index for the question 'FLEXLM_LICENSE_LOCATION' is 1
Wed 11 21:23:21 silent_install_support.c:23 setDefaultAnswer():last default answer is set to ''
Wed 11 21:23:21 silent_install_support.c:47 getUserAnswer():getting user answer on the question with id=FLEXLM_LICENSE_LOCATION
Wed 11 21:23:44 check_license.c:199 get_user_location():User has entered the location for FLEXlm license: /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:44 check_license.c:126 get_full_path():getting full path for /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:44 check_license.c:138 get_full_path():full path for /opt/intel/licenses/l_mkl_XZ98TXGF.lic is /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:44 check_license.c:760 check_license():Looking for valid FLEXlm license into the user-specified directory /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:44 shell.c:29 runShellCmd():Interpreter: 'sh'
Wed 11 21:23:44 shell.c:35 runShellCmd():Command to execute: 'uname -m 2>/dev/null'
Wed 11 21:23:44 shell.c:76 runShellCmd():Capturing STDOUT
Wed 11 21:23:44 shell.c:89 runShellCmd():GOT 7 bytes from STDOUT
Wed 11 21:23:44 shell.c:119 runShellCmd():waitpid() status for the executed command: 0
Wed 11 21:23:44 check_license.c:98 determineFLEXLM_platform():Trying to determine FLEXlm platform for machine name x86_64
Wed 11 21:23:44 check_license.c:448 check_license_file():Checking file /opt/intel/licenses/l_mkl_XZ98TXGF.lic for valid FLEXlm license
Wed 11 21:23:44 check_license.c:449 check_license_file():runpath /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e
Wed 11 21:23:44 check_license.c:450 check_license_file():-a -q
Wed 11 21:23:44 check_license.c:451 check_license_file():chklic_f_opt -fMKernL -fMKern -fCLMKernL -fCLMKern
Wed 11 21:23:44 check_license.c:452 check_license_file():chklic_c_opt -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic"
Wed 11 21:23:44 check_license.c:453 check_license_file():chklic_p_opt -pi86_r -pi86_re -pit64_lr -pit64_re
Wed 11 21:23:44 check_license.c:282 call_flexlm_chklic():Call a /tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null command.
Wed 11 21:23:44 shell.c:35 runShellCmd():Command to execute: '/tmp/install_temp.5f79b93b187f575160d7c2e7fc0ff28e/zchklic86_64 -a -fMKernL -fMKern -fCLMKernL -fCLMKern -c"/opt/intel/licenses/l_mkl_XZ98TXGF.lic" -pi86_r -pi86_re -pit64_lr -pit64_re &>/dev/null'
Wed 11 21:23:44 shell.c:119 runShellCmd():waitpid() status for the executed command: 512
Wed 11 21:23:44 check_license.c:288 call_flexlm_chklic():Chklic value 2
Wed 11 21:23:44 check_license.c:455 check_license_file():Chklic ret value is 2
Wed 11 21:23:44 check_license.c:167 chklic_evaluate():Expired FLEXlm license was found in /opt/intel/licenses/l_mkl_XZ98TXGF.lic
Wed 11 21:23:44 check_license.c:457 check_license_file():Chklic auth value is 0
Wed 11 21:23:44 check_license.c:757 check_license():Asking user to specifiy the directory to look for valid FLEXlm license
Wed 11 21:23:44 silent_install_support.c:116 getQuestionIndex():index for the question 'FLEXLM_LICENSE_LOCATION' is 1
Wed 11 21:23:44 silent_install_support.c:23 setDefaultAnswer():last default answer is set to ''
Wed 11 21:23:44 silent_install_support.c:47 getUserAnswer():getting user answer on the question with id=FLEXLM_LICENSE_LOCATION
Wed 11 21:24:05 install.c:80 fatal_exit():failed to install the product
IDZ_A_Intel
You need valid license key to install Intel MKL. Based on attached log, insteller has detected the expired license key on your machine (check_license.c:167 chklic_evaluate():Expired FLEXlm license was found in /opt/intel/licenses/l_mkl_XZ98TXGF.lic).
Could youtry to enterserial numberfrom CD during install? If it still will be unsuccessful, please attach the step-by-step procedure, we'll think about the possible workaround.
Thank you,
- Nikolay
IDZ_A_Intel
Thank you,
- Nikolay
I'm sorry, I didn't catch your message properly. You have entered the serial number.
Could youbackup directory/opt/intel/licenses and then remove it? Will issue still be reproduced? And what version of MKL are you trying to install?
Thank you, - Nikolay
liangmz
we brought 3 copies of the Linux Intel MKL 10.0 . I tried all 3 serials that were inside the CD case and all of them gave the same error. Is there a secure way to verify those serials are valid?
thx
mike
IDZ_A_Intel
Hello Mike,
I'll check serial numbers setwith latest packages and return to you with result in 1-2 days.
Then we can think about the workaround.
Or you can submit the issue against MKL to Premier support ( https://premier.intel.com/ ) to validate serial numbers.
Thank you,
- Nikolay
IDZ_A_Intel
Hello Mike,
I verified serial numbers with MKL package, it works fine on my side. Did you contact MKL support?
Thank you,
- Nikolay
