7303 Discussions
cannot find ScaLAPACK libraries in Composer XE 2015 for C++ Linux
Sergei_C_
I've downloaded Intel Parallel Studio XE Composed Edition for C++ Linux, (composer_xe_2015)  and tried to compile a test program for ScaLAPACK.  However, I cannot find the ScaLAPACK libraries in the lib/intel64.  The only version of libmkl_scalapack_lp64 resides in the lib/mic directory, and LD skips this as incompatible.
Am I missing anything, or ScaLAPACK is not included in the version of MKL distributed with Composer XE 2015?
Thanks for your help!
Zhang_Z_Intel
The cluster components of MKL, including ScaLAPACK, are not installed by default. You'll have to re-run your installation process and manually explicitly select these components. See this article for more information: https://software.intel.com/en-us/articles/intelr-mkl-new-install-option
Zhang_Z_Intel
Sergei_C_
Thank you, that helped!
I just ran install script again and customized the list of installed components.  It's strange, though, that default ScaLAPACK is isntalled for MIC, and not for the common linux64 architecture...
