- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I am compiling a correct example (taken from here), but I am getting:
gsamaras@pythagoras:~/intel/code$ ../bin/icc -mkl nine_by_nine.c -o n nine_by_nine.c(2): catastrophic error: cannot open source file "iostream" #include <iostream>
If I compile with mpicc nine_by_nine.c -l../../mpich-install ${MKLROOT}/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a ${MKLROOT}/lib/intel64/libmkl_core.a ${MKLROOT}/lib/intel64/libmkl_intel_thread.a -Wl,--end-group ${MKLROOT}/lib/intel64/libmkl_blacs_intelmpi_lp64.a -liomp5 -ldl -lpthread -lm, as suggested here, I am getting the very same error message.
What should I do?
Notice that this does not seem to help me.
EDIT:
An example that includes these headers works just fine:
#include <stdio.h> #include <stdlib.h> #include "mkl.h"
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tim,
I really want to clear up the confusion, but I didn't have what you have in mind. Not sure if I have it now too, to be accurate. First of all,, there is no such thing as mpiCC in my MPICH2 installation. See first code block of post #6, which lists what it has. So you mean how am I compiling a C++ with MPI program? If this is the case (if not, *please* let me know and I will report back ASAP), then I would do this (for compiling this .cpp example):
gsamaras@pythagoras:~/mpich-3.1.4/code$ ../../mpich-install/bin/mpic++ ring.cpp -o r gsamaras@pythagoras:~/mpich-3.1.4/code$ mpiexec -n 2 ./r
This won't compile with g++, because of MPI errors.
Notice that I also tried to compile what I have in post #6 with g++, but it didn't recognize -mkl again.
George
EDIT:
It compiled with:
../mpich-install/bin/mpic++ -o test n.cpp -I../intel/mkl/include ../intel/mkl/lib/intel64/libmkl_scalapack_ilp64.a -Wl,--start-group ../intel/mkl/lib/intel64/libmkl_intel_ilp64.a ../intel/mkl/lib/intel64/libmkl_core.a ../intel/mkl/lib/intel64/libmkl_sequential.a -Wl,--end-group ../intel/mkl/lib/intel64/libmkl_blacs_intelmpi_ilp64.a -lpthread -lm -ldl
from a new directory I created. Not sure why this worked, but it compiled by just giving a warning:
warning: deprecated conversion from string constant to âchar*â [-Wwrite-strings]
Cblacs_gridinit(&ictxt, "Row", nprow, npcol);
EDIT_2:
Just for the future users:
However, it will produce a floating point exception (which is weird, since I took it from a guy that knows what he is doing):
gsamaras@pythagoras:~/konstantis$ mpiexec -n 1 ./test Returned: Hello World! I am 0 of 1 =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 4738 RUNNING AT pythagoras = EXIT CODE: 8 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Floating point exception (signal 8) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions
and I am pretty sure that this happens in this line:
locR = numroc_(&matrix_size, &block, &myrow, &izero, &nprow);
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You should be using a C++ MPI wrapper and a C++ source file suffix (mpiicpc in the case of Intel MPI) to compile C++ MPI code. gcc will make the switch automatically when it sees source files with a C++ suffix or when -x c++ is specified, but that switchover will still not take care of the link step.
Part of this was covered in the parts of the URL you gave which you ignored.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Tim, sorry but I missed it, I didn't ignore anything. :) However, I am still unable to compile it:
gsamaras@pythagoras:~/intel/code$ ../bin/mpiicpc -mkl nine_by_nine.c -o n -bash: ../bin/mpiicpc: No such file or directory gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpiicpc -mkl nine_by_nine.c -o nnine_by_nine.c -bash: ../../mpich-install/mpiicpc: No such file or directory gsamaras@pythagoras:~/intel/code$ ../bin/icpc -mkl nine_by_nine.c -o nnine_by_nine.c /tmp/icpc3iCx8w.o: In function `main': nine_by_nine.c:(.text+0x47): undefined reference to `MPI_Init' // similar errors about MPIT
Note that `../../mpich-install` is the path where I have installed MPICH2, since it wasn't provided with MKL.
Also note that `mpiicpc` alone is not found. What am I missing?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
If you are using mpich I guess the c++ wrapper may be mpiCC but you may still need a cpp or equivalent suffix for c++ source files.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Could you try again after setting the environment for Intel Tools by sourcing the scripts located in these locations, in case you have not done so?
<your installation folder>/bin/compilervars.sh intel64 (assuming you are building for Intel64.
<your installation folder>/mkl/bin/mklvars.sh intel64
<your installation folder>/impi/x.x.x.xxx/bin64/mpivars.sh
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Tim no, I had tried what seemed to be needed for C++ and MPI, but it didn't recognize -mkl. Should have included this information in my previous post.
Vipin Kumar E, the first two worked, but the later failed, because their so no such directory as impi. Here is what I have:
gsamaras@pythagoras:~/intel/bin$ ls codecov gdb-mic icpc map_opts tselect compilervars.csh icc inspxe-inject profdcg xiar compilervars.sh iccvars.csh inspxe-runsc profmerge xild gdb-ia iccvars.sh inspxe-wrap proforder gsamaras@pythagoras:~/intel/bin$ ls ../ advisor_xe intel_sdp_products.db advisor_xe_2015 ipp advisor_xe_2015.1.10.380555 ism bin lib code // I created this licenses composerxe man composer_xe_2015 mkl composer_xe_2015.3.187 parallel_studio_xe_2015 include tbb inspector_xe vtune_amplifier_xe inspector_xe_2015 vtune_amplifier_xe_2015 inspector_xe_2015.1.2.379161 vtune_amplifier_xe_2015.3.0.403110 gsamaras@pythagoras:~/intel/bin$ ls ../../mpich-install/bin hydra_nameserver mpic++ mpicxx mpif77 mpirun hydra_persist mpicc mpiexec mpif90 mpivars hydra_pmi_proxy mpichversion mpiexec.hydra mpifort parkill
PS - My product is: Intel® Parallel Studio XE Professional Edition for C++ Linux* for student-use only.
EDIT:
As expected, by using the MPI compilers, MKL is not "visible", thus an error:
gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpic++ -mkl nine_by_nine.c -o n
g++: error: unrecognized command line option ‘-mkl’
gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpic++ nine_by_nine.c -o n
nine_by_nine.c:7:17: fatal error: mkl.h: No such file or directory
#include <mkl.h>
compilation terminated.
gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpicxx -mkl nine_by_nine.c -o n
gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpicc -mkl nine_by_nine.c -o n
gcc: error: unrecognized command line option ‘-mkl’
EDIT_2:
I created a new file, with a .cpp extension, instead of .c. However, the errors are still alive:
gsamaras@pythagoras:~/intel/code$ ../../mpich-install/bin/mpicxx nine_by_nine.cpp -o n -I/../../intel/include
nine_by_nine.cpp:7:17: fatal error: mkl.h: No such file or directory
#include <mkl.h>
mpicxx nine_by_nine.cpp -l../../mpich-install ${MKLROOT}/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a ${MKLROOT}/lib/intel64/libmkl_core.a ${MKLROOT}/lib/intel64/libmkl_intel_thread.a -Wl,--end-group ${MKLROOT}/lib/intel64/libmkl_blacs_intelmpi_lp64.a -liomp5 -ldl -lpthread -lm
g++: error: /lib/intel64/libmkl_scalapack_lp64.a: No such file or directory
g++: error: /lib/intel64/libmkl_intel_lp64.a: No such file or directory
g++: error: /lib/intel64/libmkl_core.a: No such file or directory
g++: error: /lib/intel64/libmkl_intel_thread.a: No such file or directory
g++: error: /lib/intel64/libmkl_blacs_intelmpi_lp64.a: No such file or directory
Same errors with mpic++ and mpicc. I also checked manually for '/lib/intel64/libmkl_scalapack_lp64.a' for example, but it's not there! I am really stuck, what I should do?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
If your mpiCC doesn't recognize -mkl i would guess it's configured to use g++
You would check mpich docs on how to fix that with mpich.
it doesn't make sense to continue with this thread if you don't intend to clear up this confusion .
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tim,
George
EDIT:
It compiled with:
EDIT_2:
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
If your mpich wrapper is spelled mpic++, that's a new one to me, but you could do e.g.
mpic++ -v
or mpic++ -V
to see whether it is attached to g++ or icpc.
-mkl option is peculiar to Intel compilers. The link advisor app on the Intel site documents how to link with g++ linux and mac (or with Intel compilers, if you want something different from what is included in -mkl options).
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Tim,
I guess mpiCC would be the older version. Well, why would it be attached to icpc? I mean I installed MPICH2 and it's standalone. Here is also the output of -v:
gsamaras@pythagoras:$ mpic++ -v mpicxx for MPICH version 3.1.4 Using built-in specs. COLLECT_GCC=g++ COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.9/lto-wrapper Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Debian 4.9.2-10' --with-bugurl=file:///usr/share/doc/gcc-4.9/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.9 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.9 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.9-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.9-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --with-arch-32=i586 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Thread model: posix gcc version 4.9.2 (Debian 4.9.2-10)
By the way, if somebody finds the bug in the example I compiled, it would be nice to let us know.
Thanks guys.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You are running mpich built to use g++, so it is expected to behave as g++ rather than icc or icpc. When g++ compiles a .c source file, without the option -x c++, it might be expected not to handle C++ include files, even though it accepts it as input to gcc. Nor will it understand the -mkl option, so you must refer to the link advisor https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/ for advice on options for compiling and linking with g++ against MKL.
Any up to date mpich site should document how to make mpich C++ wrapper invoke icpc. There is sufficient compatibility between g++ and icpc (including ability to share libstc++) that it may not require a completely separate build of mpich, although that is the usual way in my experience. If you want separate g++ and icpc builds of mpich to coexistm a likely method would be to build and install in separate directories. You have done the right thing by having that mpich-install directory for your g++ mpich build, rather than putting it on one of the default system paths; you would need another such directory for a separate icpc build.
You could quite likely build files which don't include any mpi headers with icpc and include them in a build using mpich g++, but that is a higher level of complication.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
