cblas_sgemv_batch_strided threading problem
MicPac
with intel oneApi 2023.0:
I try to force cblas_sgemv_batch_strided to run on ONE thread.
I set :
mkl_set_num_threads_local( 1 )
or
mkl_domain_set_num_threads(1, MKL_DOMAIN_BLAS)
or
mkl_domain_set_num_threads(1, MKL_DOMAIN_ALL);
or both
but I can see a lot of tbb thread in all cases
I can see one thread only if I set MKL_THREADING sequential before my cmake find_package
but it's not possible in my use case
Is it a bug of that gemv function ?
With my best regards,
Michel
SofeaAzrin_A_Intel
Based on your previous comments, you are using the openMP related routine.
or mkl_domain_set_num_threads(1, MKL_DOMAIN_BLAS)
Thus, you need to link with openMP but not with TBB. For further details and understanding, you can refer to our user guide or get started documents.
SofeaAzrin_A_Intel
SofeaAzrin_A_Intel
We recommend you to look in TBB runtime design. The function that you mentioned is not possible to do.
