cluster fft routines openmp support?
giorgos17
Greetings,
I am developing an MPI application for a cluster of SMP systems. It is built around the MKL cluster FFT
routines. Can these routines take advantage of OpenMP threads, or should I start multiple MPI processes
on each SMP system?
Thank you.
Gennady_F_Intel
Quoting giorgos17
on each SMP system?
Can these routines take advantage of OpenMP threads -
not at this moment. We are going to implement this opportunityin the nearest version of MKL.
on each SMP system? What MPI version are you going to use? if we are talking about Intel MPI version, then we recommend you to use version 3.2.1 which really support the hybridmode.
--Gennady
giorgos17
I am planning to use MPICH2
Vladimir_Petrov__Int
New Contributor III
As Gennady mentioned, current implementation performs best if only MPI parallelization is used. Support for MPI+OpenMP parallelization will be added in the nearest future.
-Vladimir
giorgos17
Thank you for your response.
Giorgos
