compiling and linking
anand_b_
i have to compile and link using mkl
the command to be used is
ifort -w -o abc abc.f p.f q.f -mkl=sequential -L/lib -lmyvc -lmyfg
sometimes this command works. at times it gives error that -lmyvc/ libmyvc.a / -lmyvc not found. then i have to place libmyvc.a and libmyfg.a in source codes folder and give above command it creates executable abc.
i feel the problem is due to non linking of .a files with mkl=sequential.
how can i overcome this problem
anand
TimP
Mkl link advisor covers static library linking.  You must pay attention to order of libraries and group directives.
