7302 Discussions
ddot function returning single precision result
jpharvey1981
Hi everyone,
I have the following function in a Fortran project (built in the Visual studio 2010 environment + Intel Compiler XE) that uses one of the MKL library functions (the ddot function that computes a vector-vector dot product):
 function Calculate_Potential_Energy_From_Clusters(nb_clusters,Tetra_Mol_Array,Cluster_Pot_energy_Array)
 use Mod
 integer nb_clusters,n
 double precision Calculate_Potential_Energy_From_Clusters,Tetra_Mol_Array(nb_clusters),Cluster_Pot_energy_Array(nb_clusters)
  Calculate_Potential_Energy_From_Clusters=ddot(nb_clusters,Tetra_Mol_Array,1,Cluster_Pot_energy_Array,1)
 end
The project is compiled without any error or warning...
However, if I do not specify explicitly the type of the ddot function result, the MKL library return a single precision number (even if I specify the use of ddot, not sdot).
I solved the problem by defining explicitly the type of ddot in my function:
 use Mod
 double precision ddot, Calculate_Potential_Energy_From_Clusters,Tetra_Mol_Array(nb_clusters),Cluster_Pot_energy_Array(nb_clusters)
 end
Is it normal that the intel XE compiler assumes that the result of the ddot function is of single precision when ddot function is not explicitly defined as a double precision number (ddot is supposed to return a double precision result)?
If so, what should I do to avoid this problem?
Thank you very much for your help!
mecej4
This behavior is what the Fortran language rules prescribe, and is not specific to the Intel compiler.
Any function that is not an intrinsic function has a type that is given by implicit typing rules. If you had declared IMPLICIT NONE in the subprogram where you invoked DDOT, the compiler would have complained that the variable/function did not have a declared type. In the absence of a type declaration, DDOT is a name beginning with a letter other than I, J, K, L, M, N and, therefore, of type real if IMPLICIT NONE has not been specified.
