dgels in 10.0.1.015 -> 10.0.2.019
andipandi
Dear Board!
I just installed the 10 Update 2 Version of MKL, and the dgels function seems not to be working anymore. When I do a debug-break in Visual Studio 2005, I see that the Call stack is something like (highest being most current)
kmp_wait_sleep
kmp_join_barrier
kmp_internal_join
kmp_join_call
kmpc_fork_call
_mkl_lapack_dgeqrf
mkl_lapack_dgels
degls
Dont know if I call the function correctly, since the documentation on this function is not clear for me (didnt understand lda and ldb), but it certainly works under 10 Update 1.
Other functions like the fft ones still work.
Thanks for any help
TimP
lda and ldb are the "leading dimensions" of matrices a and b (the length of the columns as actually stored, in case they are stored in a matrix which is dimensioned larger than necessary). The minimum values are OK:
http://www.netlib.org/lapack/double/dgels.f
Also, check that your lwork value is sufficient, preferably at least "optimal."
andipandi
Thx for your reply!
Lwork is big enough, after all, from the documentation I understood that the function generates an error in the info variable but returns immediately?!
But in my case, the dgels function just hangs (with the call stack as written in my last post).
For lda I simply take m, as for ldb as well (since it should be max(m,n)?) since I always have an overdetermined matrix with m > n.
But, like I said, it hangs, without an error message. And I tried with 2 different installs of the MKL 10 Update 2, where the same code works with MKL 10 Update 1.
If this adds any information, I have an overdetermined system that I try to approximate, with just a 1-dimensional result vector b. trans = 'N'.
andipandi
Anyone at Iintel willing to answer my question?
Or maybe ask some question where I need to provide further details?
By the way, when debugging/testing, I call this code during an "attach dll". Might this cause any problems (no threads can be created at this point).
TimP
It looks like you should file a problem report on premier.intel.com, providing the test case which shows the different behavior of these MKL versions.
andipandi
So.. like I mentioned, the problem occured during startup, so I suppose that in the new version you have some kind of clever threading implemented which - in the startup (dll attachment) does not work (creation of threads is delayed till after attachment).
When calling the code at a later point, there is no problem.
I also changed to custom building an MKL dll due to other problems..
Problem solved, and many thanks!
rahewin
I also encountered the same problem. So how do you fix it?
