dgelss does not work
Hai
I am working on function "dgelss" to simulate pinv in Matlab. After I called dgelss() in MKL (lapack), the output info will be 0 which means execution is successful. But the result matrix does not provide the correct value. Can someone help me figure out why?
MKL version: 10.2.2.025
int main(int argc, char *argv[])
    Init();
    int step_extended, step_orig;
    int unitMatrixSize = 1;
    IppStatus status;
    int m = 3, n = 3, nrhs = 1;
    float *matrixA = (float *)malloc(sizeof(float)*m*n);
    //Data Matrix, size is 3x3
    matrixA[0] =    11.0;
    matrixA[1] =    9.0;
    matrixA[2] =    -6.0;
    matrixA[3] =    3.0;
    matrixA[4] =    -3.0;
    matrixA[5] =    0.0;
    matrixA[6] =    -3.0;
    matrixA[7] =    0.0;
    matrixA[8] =    1.0;
    //identity matrix, size is 3x3
    float * unitMatrix = (float *)malloc(sizeof(float) * 9);
    for(int i = 0; i < 3; i++)
        for(int j = 0; j < 3; j++)
            unitMatrix[j*m+i] = 0.0;
    unitMatrix[0] = 1.0;
    unitMatrix[4] = 1.0;
    unitMatrix[8] = 1.0;
    int lda = m;
    int ldb = m;
    double work;
    int rank = -1, info, lwork=-1;
    float rcond = .01;
    int dim = min(m,n);
    float *S = (float *)malloc(sizeof(float) *dim);
    float *WORK = (float *)malloc(sizeof(float) *1);
    sgelss(&m, &n, &m, matrixA, &lda, unitMatrix,&ldb, S, &rcond, &rank, WORK, &lwork, &info);
    free(matrixA);
    free(unitMatrix);
    free(S);
    free(WORK);
    return TRUE;
mecej4
On what basis do you rest this claim? The matrix you gave is of full rank. Therefore, the minimum norm solution is the same as the result of Gaussian elimination, and the minimum residuals are zero. Are you aware that you are calling the Fortran77 routine and, therefore, the input matrices are expected to be in column major order?
The matrix, as entered in your program, is
11   3  -3
 9 -3  0
-6  0  1
Is this the matrix you wanted, or its transpose?
Hai
thanks for your reply first.
What I want to do is to find the psuedo inverse of a given matrix. The size of the matrix is arbitrary. In my code, I use 3x3 as an example. For the matrix B in ?gelss, I used a identity matrix. Then the result should be the psuedo inverse of input matrix A. I did not notice about the column major order issue. But right now, I just cannot get even a look-good result.
For example, if I use Matlab to compute, if the input matrix A is:
[11   3  -3
 9 -3  0
-6  0  1]
Then the result matrix B should be pinv(A)
     [0.5000    0.5000    1.5000
    1.5000    1.1667    4.5000
    3.0000    3.0000   10.0000]
thanks
11   3  -3
 9 -3  0
-6  0  1
mecej4
I see that in your C++ caller you set lwork = -1. That is the convention for asking Lapack to tell you how much workspace is required. Such a call does not do anything else. You have to take the value returned in lwork, allocate that much real workspace, and call Lapack again (with lwork unchanged) to do the actual calculation of the pseudoinverse.
mecej4
Duplicate Message: Please Delete!
Hai
Yeah, it works. I know this trick now.
thanks mecej4!
