different results for zheev
vladaz
I use zheev in program which is written in fortran90. I get the different results from zheev for the input matrix 70x70 when I use ('version of MKL libraries 10.2.2.025 and fortran compiler version /intel/Compiler/11.1/056/mkl/lib/32' that give correct results) and ('MKL libraries 10.2.3.029 and fortran compiler version intel/Compiler/11.1/064/mkl/lib/em64t/' that give incorrect results).
Can somebody tell me where is the problem?
Vlada
mecej4
It would be very helpful if you provided source code to demonstrate the behavior that you described.
Gennady_F_Intel
Vlada,
We had similar problem earlier. Could you please look inMKL 10.2 Fixes list. "Zheevd produces different output 'info' on different systems."
--Gennady
