dss_solve_real
siva
I am trying to do the following with the MKL direct sparse solver. (I am using Intel Fortran 11.0.066 and MKL 10.1.0)
I have a symmetricpositive definite sparse matrix. After factoring it, I do
1. solve with MKL_DSS_FORWARD_SOLVE optionfollowed by solve with MKL_DSS_BACKWARD_SOLVE option
2. solve with MKL_DSS_DEFAULTS options
They should both give the same answer, but they don't.
I have attached a file where the matrix I am using is diagonal A = [2 0; 0 2]
Could you please tell me what I am doing wrong?
Thank you.
Siva
[cpp]include 'mkl_dss.f90'
program main
use mkl_dss
implicit none
type(MKL_DSS_HANDLE) :: hDSS
double precision :: values(3)
integer :: rowIndex(3), columns(3)
integer :: perm(2)
double precision :: rhs(2), x1(2), x2(2), x(2)
values = 0.d0
values(1) = 2.d0
values(2) = 0.d0
values(3) = 2.d0
columns(1) = 1
columns(2) = 2
columns(3) = 2
rowIndex(1) = 1
rowIndex(2) = 3
rowIndex(3) = 4
rhs(1) = 1.d0
rhs(2) = 0.d0
perm(1) = 1
perm(2) = 2
if (dss_create( hDSS, MKL_DSS_DEFAULTS ) .ne. MKL_DSS_SUCCESS) then
    print*,'Error creating'
    stop
endif
if (dss_define_structure( hDSS, MKL_DSS_SYMMETRIC, rowIndex, 2, 2, columns, 3) &
    print*,'Error defining structure'
    stop
endif
if (dss_reorder( hDSS, MKL_DSS_AUTO_ORDER, perm ) .ne. MKL_DSS_SUCCESS)  then
    print*,'Error reordering'
    stop
endif
if (dss_factor_real( hDSS, MKL_DSS_POSITIVE_DEFINITE, values ) &
    print*,'Error factoring'
    stop
endif
if (dss_solve_real( hDSS, MKL_DSS_FORWARD_SOLVE, rhs, 1, x1 ) &
    print*,'Error forward solving'
    stop
endif
print*,x1
if (dss_solve_real( hDSS, MKL_DSS_BACKWARD_SOLVE, x1, 1, x2 ) &
    print*,'Error backward solving'
    stop
endif
print*,x2
if (dss_solve_real( hDSS, MKL_DSS_DEFAULTS, rhs, 1, x ) &
    print*,'Error solving'
    stop
endif
print*,x
end program main[/cpp]
siva
Got it, have to do
MKL_DSS_FORWARD_SOLVE+MKL_DSS_REFINEMENT_OFF
etc. (see pardiso and dss documentation)
Thank you.
Siva
program main
use mkl_dss
implicit none
integer :: perm(2)
values = 0.d0
values(1) = 2.d0
values(2) = 0.d0
values(3) = 2.d0
columns(1) = 1
columns(2) = 2
columns(3) = 2
rowIndex(1) = 1
rowIndex(2) = 3
rowIndex(3) = 4
rhs(1) = 1.d0
rhs(2) = 0.d0
perm(1) = 1
perm(2) = 2
    stop
endif
    stop
endif
    stop
endif
    stop
endif
    stop
endif
print*,x1
    stop
endif
print*,x2
    stop
endif
print*,x
Sergey_P_Intel2
Hi, Siva!
Thank you for the question. Youhave found in MKL documentation the correct solution of the problem. Currently by default DSSperforms up to tworefinementstepsfor better accuracy.Butafter forward (and diagonal) substitutions this should lead to wrong solution because refinement isperformed with original matrix. So, refinement stepsare incompatible with forward (and diagonal) solving steps, butDSSprovides full controlof these parameters (MKL_DSS_REFINEMENT_OFF and MKL_DSS_REFINEMENT_ON, MKL_DSS_FORWARD_SOLVE etc.). Of course, PARDISO isoperatedby corresponding iparm values, too.
Probably it will be better to switch off refinement steps in the case of forward and diagonal solving steps, but in this case it will be impossible to switchthem ON in somespecial cases, if any.
With best regards,
Sergey
