dss_solver gives non-stable solve
Tianyu_D_
Hi there,
I am using the mkl_dss.f77 to solve large sparse non-linear equations by iteratively calling the dss_solver. I just spotted that although I set the same initial values, I could not obtain a same result for every time. And I found this is due to the dss_solver gives results with slightly difference every time and the difference adds up in the iteration process which leads to a non-stable solve for the large sparse non-linear equations.
How can I make the mkl_dss solver to have repetitive accuracy? Anyone could give me some advice on this subject?
Alexander_K_Intel2
It is better to use Pardiso interface for this aim. In Pardiso interface you can use CNR mode of MKL or set iparm[33] to maximum number of threads - both approach will provide stable results from run to run.
Alex
Tianyu_D_
Hi Alex,
Thank you for your reply.
The reason I did not use Pardiso is that DSS provides the function dss_reorder which could help to save time since I only need to reorder once in the iteration process.
So if I want to keep using DSS, any suggestion for me to make its output stable?
Tianyu
Gennady_F_Intel
and also matrix checker option available with Pardiso API too. see ipatr(27). This functionality is not available for DSS API.
Alexander_K_Intel2
Hi Tianyu,
Almost all that can be done via DSS interface can be implemented via PARDISO. Reordering step DSS_reorder correspondent to pardiso call with ido=11. But it is not quite good approach to call reordering only once for all matrix except symmetric-positive define, because good reordering step for all other matrix significantly depend on matrix value. Can you provide some pseudo-code of you algorithm that we can change to show how it can be done via PARDISO interface?
Alex
Tianyu_D_
     Here is my codes.
Thank you so much.
 SUBROUTINE NFDSS_SOLVE(XDIFF,IU,JU,UM,nRow0,ITER,Idum)
      INCLUDE 'mkl_dss.f77'
      !INCLUDE 'mkl_pardiso.f77'
      INTEGER IU(*), JU(*), Idum(*), nRow0, nRow, ITER
      REAL  UM(*), XDIFF(*)
      INTEGER tIU(:), tJU(:)
      DOUBLE PRECISION tUM(:), tXDIFF(:), tX(:)
      ALLOCATABLE tIU, tJU, tUM, tXDIFF, tX
      INTEGER nNonZeros, nNonZeros0
      INTEGER*8 handle
      INTEGER error
      nNonZeros0=IU(nRow0+1)-1;
      nRow=nRow0-2;
      nNonZeros=nNonZeros0-2;
      ALLOCATE(tIU(nRow+1))
      ALLOCATE(tXDIFF(nRow))
      ALLOCATE(tX(nRow))
      ALLOCATE(tJU(nNonZeros))
      ALLOCATE(tUM(nNonZeros))
      tIU(1:nRow+1)=IU(3:nRow+3)-2
      tJU(1:nNonZeros)=JU(3:nNonZeros+2)-2
      tUM(1:nNonZeros)=UM(3:nNonZeros+2)
      tXDIFF(1:nRow)=XDIFF(3:nRow+3)
C---------------------------------------------------------------------------
C Initialize the solver
      error = dss_create(handle, MKL_DSS_DEFAULTS+MKL_DSS_OOC_VARIABLE)
      IF (error .NE. MKL_DSS_SUCCESS ) GOTO 999
C Define the non-zero structure of the matrix
      error = dss_define_structure( handle, MKL_DSS_NON_SYMMETRIC,
     & tIU, nRow, nRow, tJU, nNonZeros )
C Reorder the matrix
      IF (ITER.EQ.1) THEN
          error = dss_reorder( handle, MKL_DSS_GET_ORDER, Idum)
      ELSE
          error = dss_reorder( handle, MKL_DSS_MY_ORDER, Idum)
      ENDIF
C Factor the matrix
      error = dss_factor_real( handle, MKL_DSS_DEFAULTS, tUM)
C Get the solution vector
      error = dss_solve_real( handle, MKL_DSS_DEFAULTS,
     & tXDIFF, 1, tX)
C Deallocate solver storage
      error = dss_delete( handle, MKL_DSS_DEFAULTS )
      GOTO 1999
  999 WRITE(*,*) "Solver returned error code ", error
 1999 XDIFF(3:nRow+2)= tX(1:nRow)
      DEALLOCATE(tIU,tJU,tUM,tXDIFF,tX)
      RETURN
      END
Tianyu_D_
Hi Alex,
The attached is my code.
