dsyev crashes on a simple matrix
ansobolev
Thanks for solving the previous issue. I can confirm that it has indeed been fixed.
With MKL 2026.0 we encountered another issue: when trying to calculate the eigenvalues of a simple matrix with dsyev, we get floating divide by zero. The MWE is below:
program dsyev_example
  implicit none
  real*8 :: matrix(3,3), ev(3), work(8)
  integer :: info
  matrix(:, 1) = (/523.720904015851,   0.0,              0.0              /).
  matrix(:, 2) = (/-87.7269993344388,  509.765510517387, 0.0              /)
  matrix(:, 3) = (/-87.7269993344388, -114.410201478550, 509.765510517387 /)
  call dsyev( 'V', 'U', 3, matrix, 3, ev, work, 8, info )
  print *, "Eigenvalues:"
  print *, ev
end program dsyev_example
When compiling this with `-fpe0`, we get
forrtl: error (73): floating divide by zero
Image              PC                Routine            Line        Source
libc.so.6          0000126CD7845330  Unknown               Unknown  Unknown
libmkl_core.so.3   0000126CD8EFA69F  mkl_lapack_dlaq5      Unknown  Unknown
libmkl_core.so.3   0000126CD8FAB391  mkl_lapack_dsteqr     Unknown  Unknown
libmkl_core.so.3   0000126CD8FB21C7  mkl_lapack_dsyev      Unknown  Unknown
libmkl_intel_lp64  0000126CDFE6A1D6  dsyev_                Unknown  Unknown
a.out              00000000004053A5  Unknown               Unknown  Unknown
a.out              000000000040528D  Unknown               Unknown  Unknown
libc.so.6          0000126CD782A1CA  Unknown               Unknown  Unknown
libc.so.6          0000126CD782A28B  __libc_start_main     Unknown  Unknown
a.out              00000000004051A5  Unknown               Unknown  Unknown
MKL 2025.3 and 2026.0 without `-mpe0` give the same correct results:
 Eigenvalues:
   319.854583405053        599.221603728736        624.175704956055
Thanks in advance.
Fengrui
Thanks for reporting this issue. I can reproduce it on my side. The oneMKL 2025.3 release doesn't have this issue.
We are currently working on it. I will keep you posted.
Fengrui
Fengrui
It turns out to be a known issue. It has been fixed and fix will be included in the next oneMKL release.
ansobolev
Do you mean 2026.0.1 or 2026.1.0 by the next release?
Fengrui
According to the current plan, that would be the next update release, 2026.1.0.
ansobolev
Hi @Fengrui, I checked it and this issue seems to still persist in MKL 2026.1.
Fengrui
Apologies for the mistake. It is actually included in the 2026.2 release which is scheduled to launch early October.
