dtrnlspbc_init problem
skyboating
Hi, All,
when i use the trust region algorithm, i meet some problem with "dtrnlspbc_init"
What i got is the return of "TR_INVALID_OPTION"
I have checked my parameters, it seems there is no obvious error.
I don't know what else situation, such kind of return may happen?
thank you very much!
ArturGuzik
Valued Contributor I
Quoting - skyboating
Hi, All,
Can you show the appriopriate lines of code (with parameter(s)) values? It's hard to give any advice without it.
A.
skyboating
Quoting - ArturGuzik
A.
Thank you very much for your kind reply.
I have tried the standard example, it doesn't succeed either.
So i modify the link library and it works now.
I am a green hand in intel library.
i don't know what is the
difference between ilp64 and lp64?
my CPU is Core 2 Duo, and my system is Win XP 64.
ArturGuzik
well, I didn't help you at all. ilp64 and lp64 are integer models specific for x64 platform. Take a look at Chapter 3 Support for ILP64 Programming in User's Manual.
A.
skyboating
A.
thank you very much any way.
it is nice to get your advice here.
