7303 Discussions
error #6285: There is no matching specific subroutine for this generic subroutine call. [LIN_SOL_GEN]
27081984
I have a problem concerning the use of the subroutine LIN_SOL_GEN to compute a matrix inversion.
The following error appears:error #6285: There is no matching specific subroutine for this generic subroutine call.
I show my code below.
PROGRAM INVM
! PROGRAM INVM VS. 1.0 19-OCT-2010 !
! MATRIX INVERSION
! LIBRERIA IMSL
INCLUDE 'link_fnl_static.h'
!DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
USE LIN_SOL_GEN_INT
IMPLICIT REAL(8) (A-H,O-Z)
REAL(8),ALLOCATABLE :: A(:,:),B(:,:),INV(:,:),X(:,:),RES(:,:)
REAL(8),DIMENSION(2) :: DETR,DETR_INV
WRITE(*,*) 'Matrix dimension:'
READ(*,*) N
ALLOCATE(A(N,N),B(N,0),INV(N,N),X(N,0),RES(N,N),STAT=IK)
IF(IK/=0) THEN
WRITE(*,*) 'Error: no allocation!'
STOP
ENDIF
! Compute the matrix inverse and its determinant.
DO I=1,N
B(I,0)=1.D0
ENDDO
CALL LIN_SOL_GEN(A,B,X,NHRS=0,AINV=INV,DET=DETR)
! Compute the determinant for the inverse matrix.
CALL LIN_SOL_GEN(INV,B,X,NHRS=0,DET=DETR_INV)
! Check residuals, A times inverse = Identity.
RES=MATMUL(A,INV)
DO I=1,N
RES(I,I)=RES(I,I)-1.D0
ENDDO
WRITE(*,*) INV
STOP
END
Thank you very much,
AM
mecej4
You misspelled the keyword argument NRHS.
You will encounter run-time errors since you are not properly allocating and initializing the input arrays to the IMSL routine. It would be useful to compile with checks turned on until you correct these errors.
