error in including library vslf
fymaterials
Hi, guys:
I want to use vslf packages.
The mkl library is under directory: /home/fengy/mkl/10.0.3.020/
The makefile is like this:
# application name
APP = test
# list of source files
SRC = test.f90
# list of object files
OBJ = test.o
# list of include directory
DIR1 = /home/fengy/mkl/10.0.3.020/include
DIR2 = /home/fengy/mkl/10.0.3.020/examples/vslf/source
# define libraries needed by the linker
LIBS = -L/home/fengy/mkl/10.0.3.020/lib/em64t /home/fengy/mkl/10.0.3.020/lib/em64t/libmkl_intel_lp64.a -Wl,--start-group /home/fengy/mkl/10.0.3.020/lib/em64t/libmkl_intel_thread.a /home/fengy/mkl/10.0.3.020/lib/em64t/libmkl_core.a -Wl,--end-group /home/fengy/mkl/10.0.3.020/lib/em64t/libguide.a -lpthread
# compiler options for debugging
FC_DEBUG = ifort -I ${DIR1} -I ${DIR2} -g -debug all -check all -implicitnone -warn all
# compiler options for optmized running
FC_OPT = ifort --I ${DIR1} -I ${DIR2} O3 -xO -ipo -no-prec-div -static
# build rules
.SUFFIXES: .f90 .o .mod
.f90.o:
${FC_DEBUG} -c INCLUDE '/home/fengy/mkl/10.0.3.020/include/mkl_vkl.fi'
INCLUDE '/home/fengy/mkl/10.0.3.020/example/vslf/errcheck.inc'
!INCLUDE 'mkl_vkl.fi'
!INCLUDE 'errcheck.inc'
PROGRAM test_g_r
USE MKL_VSL_TYPE
USE MKL_VSL
IMPLICIT NONE
INTEGER(KIND=4) i, nn
INTEGER n
INTEGER(KIND=4) errcode
INTEGER brng, method, seed
TYPE(VSL_STREAM_STATE) :: stream
REAL a, sigma
REAL, DIMENSION(1) :: r
n=1
brng = VSL_BRNG_MCG31
method = 0
seed = 777
errcode = vslnewstream(stream, brng, seed)
CALL CheckVslError(errcode)
errcode = vsrnggaussian(method, stream, n, r, a, sigma)
WRITE(*,*) 'now r is: ', r(1)
END PROGRAM test_g_rlt;
debug: ${OBJ} ${SRC}
${FC_DEBUG} -o ${APP} ${OBJ} ${LIBS}
opt: ${SRC}
${FC_OPT} -o ${APP} ${SRC} ${LIBS}
clean:
rm -f *.mod *.o ${APP}
And the source file test.f90 is:
PROGRAM test_g_r
USE MKL_VSL_TYPE
USE MKL_VSL
IMPLICIT NONE
INTEGER n
REAL a, sigma
n=1
method = 0
seed = 777
When I type make -debug, an error message appears: Cannot open include file '/home/fengy/mkl/10.0.3.020/include/mkl_vkl.fi
but mkl_vki is uder directory /home/fengy/mkl/10.0.3.020/include/mkl_vkl.fi
Could you help me to figure it out what wrong with my code?
Thanks!
Arthur
Andrey_N_Intel
Can you replace mkl_vkl.fi with mkl_vsl.fieverywhere in your example and let me know how it works? Andrey
fymaterials
Thanks, Andrey, now it is working. But I get a warning message: Warning: /home/fengy/mkl/10.0.3.020/include/mkl_vsl.fi, line 297: This name has not been given an explicit type. [VSL_USER_INIT_DIRECTION_NUMBERS]
PARAMETER (VSL_USER_INIT_DIRECTION_NUMBERS = 2)
Is it normal?
Arthur
Andrey_N_Intel
This is not normal, thank you for letting us know. The issue will be fixed in future versions of the library. Andrey
