example files fail when compiled on windows
greiner08
I've recently compiled mkl example files like pardiso_unsym_c.c and others on windows using pgi compilers. Specifically, I use the lines
set "MKL_ROOT=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2019.1.144\windows\mkl"
set "MKL_LIBS=%MKL_ROOT%\lib\intel64_win"
pgcc -DMKL_ILP64 -I"%MKL_ROOT%\include" -c pardiso_unsym_c.c
pgcc pardiso_unsym_c.obj -L"%MKL_LIBS%" mkl_intel_ilp64.lib mkl_sequential.lib mkl_core.lib
It compiles without error. However, when I attempt to run the resultant .exe file, I get the error message
Error during symbolic factorisation: -1
The pardiso error codes (listed here) say this means there is "input inconsistency". As the error implies, this happens during the symbolic phase (line 121 in pardiso_unsym_c.c).
Gennady_F_Intel
Thanks for report. At the first glance everything looks correct.  I have no pgcc install on my side. Could you check the problem with Microsoft compiler?
greiner08
No problem. I will try with the Microsoft compiler and see if the issue persists. FWIW When I switched from ILP64 to LP64, the examples compiled and ran successfully with pg compilers.
Gennady_F_Intel
using the same example, MKL 2019 u1, microsoft compiler, ILP64 mode, I see no problem on my side,
Below are more details about compiling, linking and execution outputs:
 cl /DMKL_ILP64  /I"MKL_ROOT\include" /Fe2019_cl.exe pardiso_unsym_c.c
MKL_ROOT\mkl_intel_ilp64.lib  MKL_ROOT\mkl_sequential.lib MKL_ROOT\mkl_core.lib
Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24215.1 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.00.24215.1
/out:2019_cl.exe
Running:
2019_cl.exe
makefile
pardiso_unsym_c.c
pardiso_unsym_c.obj
C:\4_work\_Forums\u800726>
C:\4_work\_Forums\u800726>2019_cl.exe
Reordering completed ...
Number of nonzeros in factors = 21
Number of factorization MFLOPS = 0
Factorization completed ...
Solving system with iparm[11] = 0 ...
The solution of the system is:
 x [0] = -0.522321
 x [1] = -0.008929
 x [2] =  1.220982
 x [3] = -0.504464
 x [4] = -0.214286
Relative residual = 2.275280e-16
Solving system with iparm[11] = 1 ...
 x [0] = -0.220238
 x [1] = -0.029762
 x [2] =  0.395089
 x [3] = -0.290179
 x [4] =  0.116071
Relative residual = 7.021667e-17
Solving system with iparm[11] = 2 ...
 x [0] = -0.220238
 x [1] = -0.029762
 x [2] =  0.395089
 x [3] = -0.290179
 x [4] =  0.116071
Relative residual = 1.216188e-16
