fftw2xc crashes on second use
slarkin712
I'm calling the compiled fftw2xc_ms.lib(x64) in a MFC dll (x64) that I linked it to. I call the fft functions thousands of times to align a sequence of images and when they're aligned I unload the dll. This dll is called from a MATLAB (r2010a)program. The sequence of images aligns correctly, or least the result is the same as using the genuine fftw library functions. While running the same Matlab session I call the dll again to load the same sequence and as soon as the dll gets to the fftw function calls it crashes immediately. This is the same exact data called in the same exact way. Matlab catches the error before it crashes and here is what is says:
Segmentation violation detected at Wed Dec 01 12:37:16 2010
Configuration:
MATLAB Version: 7.10.0.499 (R2010a)
MATLAB License: 505265
Operating System: Microsoft Windows 7
Window System: Version 6.1 (Build 7600)
Processor ID: x86 Family 6 Model 10 Stepping 5, GenuineIntel
Virtual Machine: Java 1.6.0_12-b04 with Sun Microsystems Inc. Java HotSpot 64-Bit Server VM mixed mode
Default Encoding: windows-1252
Fault Count: 1
Register State:
rax = 00000000663fe0e8 rbx = 00000000348f71c0
rcx = 0000000000000001 rdx = 0000000000000000
rbp = 0000000000000800 rsi = 0000000000000001
rdi = 0000000000000001 rsp = 00000000010246f8
r8 = 0000000000000000 r9 = 0000000033fb1e60
r10 = 0000000000000000 r11 = 3ff0000000000000
r12 = 000000003417d4d0 r13 = 0000000043b3af10
r14 = 0000000043e7aa10 r15 = 0000000043e7aa50
rip = 0000000047da1740 flg = 0000000000010246
Stack Trace:
[ 0] 00000000658EC720 mkl_mc3.dll+9815840 (mkl_dft_dfti_create_drmd+003504)
[ 1] 00000000078CD8B9 aqaln01.dll+055481 (FrameAlignment+014265)
If this problem is reproducible, please submit a Service Request via:
http://www.mathworks.com/support/contact_us/ts/help_request_1.html
A technical support engineer might contact you with further information.
Thank you for your help. MATLAB may attempt to recover, but even if recovery appears successful,
we recommend that you save your workspace and restart MATLAB as soon as possible.
So it looks like a pointer has gone awry, but I can't debug it. The error is reproduceable, as every time I try to call the dll from a Matlab session twice I get the same exact error message (well, thememory states are not identica)l, even regardless of the dimensions of the image that I align. These two parts of the lines are alwaysthe same:
I can't get into the code to see what the create_drmd function does, but I suppose it has something to do with creating a plan. The mkl_mc3.dll is the mkl core for i7 processors. Does anyone have any tips for debugging this?
Sean
Dmitry_B_Intel
Hi Sean,
Could you please provide additional information: what MKL version do you use, and the link line for aqaln01.dll?
For debugging ideas,you could try if the problem reproduces if you set environment variableMKL_DISABLE_FAST_MM=1. This turns of MKL memory manager that uses internal buffers that maysurvive dll unload and interfere withthe second load.Some details onMKL memory manager can be found in MKL User's Guide. If this happens to solve the issue, you may need to add processing of DLL_PROCESS_DETACH in aqaln01.dll to free MKL buffers with a call to MKL_Free_Buffers. I am not sure this is relevant to the issue you see, just an idea.
I would also recommend you to submit the issue at premier.intel.com
Dima
slarkin712
The link line is: mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib
and the MKL version is 10.3.0.104
I tried setting the environment variable, which I did through the "System Properties" part of the control panel and also tried a call to MKL_Free_Buffers, but neither worked. I'll have to submit this to premier.intel.com as you suggested.
Sean
