fftw3 & mkl on mac os
pavel_jelinek
I'm trying to compile a home-built code using fftw3 subroutines using MKL & ifort through wrappers on Mac OS. I built wrapper using GNU C compiler and it seems that wrapper is OK. however when I do linking of the code with external libraries I get an error:
Undefined symbols:
"_dfftw_destroy_plan_", referenced from:
_laplace_fft_ in laplace_fft.o
"_dfftw_execute_", referenced from:
"_dfftw_plan_dft_c2r_3d_", referenced from:
"_dfftw_plan_dft_r2c_3d_", referenced from:
ld: symbol(s) not found
it sounds like the internal soubroutines of fftw3 are not recognized. if I do that on a Linux machine, no problem appears. Could it be related to problem of two underscores in internal names? Please could somebody make a comment?
thanks in advance
jel
Mac OS 10.5 XCode 3.1
MKL v10.0.4.022
Ifort 10.1
Gennady_F_Intel
Is this ia32 or em64t ?
Do you mean that you built libfftw3xf_intel lib? If yes, can you find these symbols in this lib?
--Gennady
