7300 Discussions
first time user ---makefile linking problems
ronald_haynes
Hi everyone, I have installed mkl 8.0.1. I have the intel fortran compiler installed (and working). I have included both the makefile and partial output below.
The environment variable MKLPATH is set in the shell.
Any help would be greatly appreciated.
R Haynes
Here is the makefile:
drive: driver.o odesolve.o mynewton_nor.o xfdjac.o xfdjac1.o
ifort -o drive ${MKLPATH}/libmkl_lapack.a ${MKLPATH}/libmkl_solver.a
${MKLPATH}/libguide.a -lpthread driver.o odesolve.o mynewton_nor.o
xfdjac.o xfdjac1.o
driver.o: driver.f
ifort -c driver.f
odesolve.o: odesolve.f
ifort -c odesolve.f
mynewton_nor.o: mynewton_nor.f
ifort -c mynewton_nor.f
xfdjac.o: xfdjac.f
ifort -c xfdjac.f
xfdjac1.o: xfdjac1.f
ifort -c xfdjac1.f
Here is the output:
ifort -o drive /opt/intel/mkl/8.0.1/lib/32/libmkl_lapack.a /opt/intel/mkl/8.0.1/lib/32/libmkl_solver.a
/opt/intel/mkl/8.0.1/lib/32/libguide.a -lpthread driver.o odesolve.o mynewton_nor.o
xfdjac.o xfdjac1.o
IPO Error: unresolved : dgbtrf_
Referenced in odesolve.o
IPO Error: unresolved : dgbtrs_
Referenced in mynewton_nor.o
/opt/intel/mkl/8.0.1/lib/32/libmkl_lapack.a(_dgbtrf.o): In function `dgbtrf_':
_dgbtrf_iface.c:(.text+0x4c): undefined reference to `mkl_cfg_file'
_dgbtrf_iface.c:(.text+0x53): undefined reference to `cfg_serial'
_dgbtrf_iface.c:(.text+0x65): undefined reference to `MKL_SET_PARALLEL'
_dgbtrf_iface.c:(.text+0x96): undefined reference to `MKL_SET_SERIAL'
_dgbtrf_iface.c:(.text+0x9c): undefined reference to `cfg_serial'
/opt/intel/mkl/8.0.1/lib/32/libmkl_lapack.a(dgbtrf_omp.o): In function `mkl_lapack_dgbtrf':
ker_dgbtrf_omp.f:(.text+0x12b): undefined reference to `xerbla_'
ker_dgbtrf_omp.f:(.text+0x173): undefined reference to `mkl_serv_in_serial'
ker_dgbtrf_omp.f:(.text+0x68b): undefined reference to `idamax'
ker_dgbtrf_omp.f:(.text+0x7cc): undefined reference to `dswap'
ker_dgbtrf_omp.f:(.text+0x883): undefined reference to `dswap'
ker_dgbtrf_omp.f:(.text+0x90f): undefined reference to `dswap'
ker_dgbtrf_omp.f:(.text+0x991): undefined reference to `dscal'
ker_dgbtrf_omp.f:(.text+0xa5f): undefined reference to `dger'
ker_dgbtrf_omp.f:(.text+0xb2a): undefined reference to `dcopy'
ker_dgbtrf_omp.f:(.text+0xf81): undefined reference to `dgemm'
ker_dgbtrf_omp.f:(.text+0x107c): undefined reference to `dgemm'
ker_dgbtrf_omp.f:(.text+0x1397): undefined reference to `dgemm'
ker_dgbtrf_omp.f:(.text+0x146b): undefined reference to `dgemm'
ker_dgbtrf_omp.f:(.text+0x1738): undefined reference to `dswap'
ker_dgbtrf_omp.f:(.text+0x17d4): undefined reference to `dswap'
ker_dgbtrf_omp.f:(.text+0x187c): undefined reference to `dcopy'
TimP
You must arrange so that the library searches occur after your .o files are loaded. Usually, this is done in something like the following fashion:
ifort -L/opt/intel/mkl/8.0.1/lib/32/ -openmp *.o -lmkl_lapack -lmkl_solver
ronald_haynes
Hi, thanks for the swift reponse. So I changed the makefile to:
-lmkl_lapack -lmkl_solver -o drive
(everything else unchanged)
and make now gives the output below--- any thoughts?
output
$make
ifort -o drive -L/opt/intel/mkl/8.0.1/lib/32/
IPO Error: unresolved : mkl_cfg_file
Referenced in libmkl_lapack.a(_dgbtrf.o)
Referenced in libmkl_lapack.a(_dgbtrs.o)
IPO Error: unresolved : cfg_serial
IPO Error: unresolved : MKL_SET_PARALLEL
IPO Error: unresolved : MKL_SET_SERIAL
IPO Error: unresolved : __kmpc_global_thread_num
Referenced in libmkl_lapack.a(dgbtrf_omp.o)
IPO Error: unresolved : xerbla_
Referenced in libmkl_lapack.a(dgbtrs.o)
Referenced in libmkl_lapack.a(dgbtf2.o)
Referenced in libmkl_lapack.a(xdgbtrf.o)
IPO Error: unresolved : mkl_serv_in_serial
IPO Error: unresolved : omp_get_max_threads
IPO Error: unresolved : __kmpc_ok_to_fork
IPO Error: unresolved : __kmpc_fork_call
IPO Error: unresolved : __kmpc_serialized_parallel
IPO Error: unresolved : __kmpc_end_serialized_parallel
IPO Error: unresolved : idamax
IPO Error: unresolved : dswap
Referenced in libmkl_lapack.a(dlaswp.o)
IPO Error: unresolved : dscal
IPO Error: unresolved : dger
IPO Error: unresolved : dcopy
IPO Error: unresolved : dgemm
IPO Error: unresolved : __kmpc_for_static_init_4
IPO Error: unresolved : dtrsm
Refe renced in libmkl_lapack.a(dgbtrf_omp.o)
IPO Error: unresolved : __kmpc_for_static_fini
IPO Error: unresolved : mkl_serv_lsame
IPO Error: unresolved : dtbsv
IPO Error: unresolved : dgemv
/opt/intel/mkl/8.0.1/lib/32//libmkl_lapack.a(_dgbtrf.o): In function `dgbtrf_':
/opt/intel/mkl/8.0.1/lib/32//libmkl_lapack.a(dgbtrf_omp.o): In function `mkl_lapack_dgbtrf':
ker_dgbtrf_omp.f:(.text+0x6f): undefined reference to `__kmpc_global_thread_num'
ker_dgbtrf_omp.f:(.text+0x18c): undefined reference to `omp_get_max_threads'
ker_dgbtrf_omp.f:(.text+0x223): undefined reference to `__kmpc_ok_to_fork'
ker_dgbtrf_omp.f:(.text+0x253): undefined reference to `__kmpc_fork_call'
ker_dgbtrf_omp.f:(.text+0x26f): undefined reference to `__kmpc_serialized_parallel'
TimP
You didn't specify -lguide or -lpthread, which would be taken care of by -openmp or -parallel options to ifort. It looks like only mkl_lapack was searched successfully, as you are missing a bunch of references which the other mkl library should take care of. I haven't used 32-bit 8.0.1 myself.
TimP
After some discussion with members of the compiler team, a concensus was reached that you were correct in not using the -L and -l method for linking MKL. However, you should link the libguide provided with the compiler, not the one provided with MKL, unless you are using an old compiler version, where the libguide is older than the one provided with MKL.
ifort -o drive -i-static -openmp
xfdjac.o xfdjac1.o
The -i-static option specifies linking against the libguide.a and other static libraries provided with the compiler. The function of -openmp at link time is to add -lguide -lpthread.
Message Edited by tim18 on 03-05-2006 08:47 AM
Andrey_G_Intel2
mkl_lapack depends from main MKL library (libmkl_ia32.a/libmkl.so). You should include libmkl_ia32.a (or libmkl.so) into your link line after including mkl_lapack library.
