from explicit QR to compact form?
Azua_Garcia__Giovann
I use LAPACK_dgeqrf to compute QR factorization and this one returns a compact representation in which the Q is not formed explicitly (I believe is in the WY compact form), then I use the documented two methods to use such compact QR to solve systems of equations.
I found an algorithm that updates the QR when blocks of rows are added to the corresponding matrix but this algorithm gives back a Q and R explicitly. Now I need to convert these explicitly formed Q and R into the compact form needed to interface with MKL or LAPACK.
Are there helper MKL functions to create the compact representation given the explicit Q and R?
TIA,
Giovanni
Alexander_K_Intel3
Hello Giovanni,
You could obtain the WY representation of explicitly formed Q by running DGEQRF on the Q. It will return you R equal to identity matrix and the same Q butin the compact form.
W.B.R.,
Alexander
Hello Alexander,
Thank you, that's smart :) a good tip indeed but I meant implicitly not having to recompute the QR from scratch. In any case I understood the in and outs of the representation so I would be able to modify it myself directly with updates i.e.
upper trapezoidal: R (including the diagonal)
lower: the householder/givens rotator column vectors v_i
tau: the householder coeffiencients t_i
I can build H = I - t_i*(v_i*v_i') this last bit is an outer product that makes a matrix.
I kind of started to understand how to manually update the QR addrows, addcols, delcols. My problem is translating whatever algorithm I can think of into something that can be most efficiently integrated with MKL.
There are some implementations I know:
http://www.maths.manchester.ac.uk/~clucas/updating/
but have had trouble integrating it, and besides they are general and my case is simpler e.g. my addcols is always append column at the end.
Giovanni
