gpg keys failure prevent yum install of Intel libraries
Barak__Ron
To install intel-daal-core-2018.1-163 on CentOS, I used these two repo files:
/etc/yum.repos.d/intel-mkl.repo:
[intel-mkl-core-2018.1-163]
name='Intel(R) Intel Math Kernel Library'
baseurl=https://yum.repos.intel.com/mkl
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/mkl/setup/PUBLIC_KEY.PUB
debuglevel=10
enabled=1
/etc/yum.repos.d/intel-daal.repo:
[intel-daal-core-2018.1-163]
name='Intel(R) Data Analytics Acceleration Library' baseurl=https://yum.repos.intel.com/daal
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://yum.repos.intel.com/daal/setup/PUBLIC_KEY.PUB
debuglevel=10
enabled=1
But, from this morning, the yum install command (sudo yum install intel-daal-core-2018.1-163) fails with:
failure: repodata/repomd.xml from intel-mkl-core-2018.1-163: [Errno 256] No more mirrors to try. https://yum.repos.intel.com/mkl/repodata/repomd.xml: [Errno -1] Gpg Keys not imported, cannot verify repomd.xml for repo intel-mkl-core-2018.1-163
However, if I stop checking the gpg keys, namely - I change the repo files to:
enabled=1
gpgcheck=1
repo_gpgcheck=0
#gpgkey=https://yum.repos.intel.com/mkl/setup/PUBLIC_KEY.PUB
debuglevel=10
enabled=1
enabled=1
gpgcheck=0
repo_gpgcheck=0
#gpgkey=https://yum.repos.intel.com/daal/setup/PUBLIC_KEY.PUB
debuglevel=10
enabled=1
And do:
sudo yum clean all ; sudo rm -rf /var/cache/yum
Then sudo yum install intel-daal-core-2018.1-163 is successful.
Googling didn't find any notice from Intel that they changed something.
Does anyone know what's the reason for the yum failure of gpg keys?
KKats1
Same problem in Debian/APT feed. The key has expired today. Hope they'll fix it on Monday.
Gennady_F_Intel
Thank you for the report. the issue is escalated and we will fix the issue asap.
Gennady_F_Intel
Could you try the package once again right now?
Barak__Ron
Seems the gpg keys problems for the daal/mkl libraries is fixed.
on "Tue Oct  1 09:48:23 PDT 2019" - I executed sudo yum install intel-daal-core-2018.1-163 --downloadonly -y without any errors.[1]
Thanks, Gennady.
[1] also no errors for sudo yum install intel-mkl-core-2018.1-163 --downloadonly -y
Wilkes__Chris
Same here.  Posted https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/821891 but it isn't showing up in the https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology list of topics.
