7303 Discussions
how to integrate fft functions for fixed pt application on SA1110
Sasikumar_Rangasamy
hello all,
I am new to this forum, i have downloaded the Intel Math Kernel Library's evaluation version and installed in my pc. I have seen the example fft files, all are having float or double datatype inputs. but i want to integrate the fft with my fixed pt application which will run on SA1110-iPAQ machine.Can any of u help me to solve this problem.
Actually problem is very simple, i need to integrate the fft function with my application which has inputs of fixed pt formats and it will run on SA1110 based iPAQ. ( My appln is in c language).
Thanks in advance,
Sasikumar Rangasamy
Chao_Y_Intel
Intel MKL do not support SA1110 processor. Intel IPPlibrariessupported SA1110 before. Butthat should be very old version.
Sasikumar_Rangasamy
hi,
Thanks for ur reply. eventhough Intel MKL doesn't have support for SA1110, how to i can integrate this fft's with any fixed pt processors, whether i need to enable any macro. can u give some example code which uses fft for fixed pt applications.
And i have one more problem, i have download the Intel Software Developer suite for C++ application. By using this IDE can i able to compile my application to SA1110 processors. if so, can u tell me the Built Options to set on compiler.
And How can we profile(Benchmark) our application by using this Intel SDT , is it possible, if not how we can do the benchmarking our appln on XScale processors.
Thanks in advance,
Sasikumar Rangasamy
